Hi.
I have an automation Phat which is working well. When I click a button on a simple php webpage - hosted on a local Apache 2 server, I am trying to get 2 things to happen:
- A Prowl notification is sent to my phone (this works fine)
- The Automation Phat relay to be toggled (this doesn’t work and causes an entry in the apache error.log below)
How I set it up:
This php code fragment calls a shell script
<?php
if(isset($_GET['trigger']) && $_GET['trigger'] == 1) {
error_reporting(E_ALL);
$command = escapeshellcmd('/var/www/html/GDRelayToggle.sh');
$output = shell_exec($command);
echo $output;
GDRelayToggle.sh consists very simply of:
#!/bin/bash
python /var/www/html/GDRelayToggle.py > /dev/null
GDRelayToggle.py is a simple sequence:
#!/usr/bin/env python
import automationhat
from subprocess import call
call('/home/pi/prowl.pl -apikeyfile=/home/pi/prowl_key.txt -event="G DOOR ALERT" -notification="GD Motor" -priority=2', shell=True)
automationhat.relay.one.toggle()
time.sleep(0.3)
In /var/log/apache2/error.log
File "/var/www/html/GDRelayToggle.py", line 6, in <module>
File "/usr/lib/python2.7/dist-packages/automationhat/__init__.py", line 238, in toggle
self.write(not self.read())
File "/usr/lib/python2.7/dist-packages/automationhat/__init__.py", line 143, in read
self.setup()
File "/usr/lib/python2.7/dist-packages/automationhat/__init__.py", line 259, in setup
setup()
File "/usr/lib/python2.7/dist-packages/automationhat/__init__.py", line 354, in setup
_ads1015 = ads1015(smbus.SMBus(1))
IOError: [Errno 13] Permission denied
I tried chmod and chown the 2 scripts as follows…
-rwxr-xr-x 1 root root 297 Jun 11 21:18 GDRelayToggle.py
-rwxr-xr-x 1 root root 64 Jul 14 17:47 GDRelayToggle.sh
Run on their own - the shell script or the python code run correctly (phone alert and relay toggles on/off).
Any idea why activating these from the apache web server are causing the IOError: [Errno 13] Permission denied?
Suggestions would be most welcome - hope my first post to this forum makes sense.
Thanks,
Rob
