Goodmorning everyone, I’m testing the Automation pHAT on my RPI zero and it works great.
Now i’m using this python basic code:
#!/use/bin/env python
import automationhat
time.sleep(1)
print(“”"
Press CTRLC to exit.
value = automationhat.analog.one.read()
print(value)
time.sleep(0.25)
I need to start “recording” data and then save the data when i send a stop command.
If you’re looking for a pure Python solution, then the code below will simply write the values to a text file, until it catches a control-c, at which point it will close the file and exit. You could add something like time.strftime("%d%m%%y-%H%M%S", time.localtime())
if you want to timestamp the values.
If you want a quick and dirty solution with the code you already have, then you can just save your code as foo.py
, then in the terminal do ./foo.py > output.txt
. That will pipe the output of your program (the readings) to a text file and it should exit when you press control-c also.
#!/usr/bin/env python
import sys
time.sleep(1)
f = open("output.txt", "w")
try:
f.write(str(value) + "\n")
time.sleep(0.25)
except KeyboardInterrupt:
f.close()
sys.exit(-1)
