I have an Automationhat connected with a raspberrypi 4 with a fresh OS installed. We initially had trouble with the python3-automationhat package saying it was not installed, but then when trying to install it manually, it says it is up to date:
Checking environment...
Updating apt indexes........................
Checking hardware requirements...
Checking for packages required for GPIO control...
raspi-gpio is already installed
RPi.GPIO installed and up-to-date
I2C already enabled
Checking packages required by I2C interface...
Python 2 smbus installed and up-to-date
Python 3 smbus installed and up-to-date
Automation HAT comes with examples and documentation that you may wish to install.
Performing a full install will ensure those resources are installed,
along with all required dependencies. It may however take a while!
Do you wish to perform a full install? [y/N] y
Checking for dependencies...
python3-sn3218 is already installed
Installing python3-automationhat...
install ok installed
Installing Automation HAT library for Python 3...
**error**: **externally-managed-environment**
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
**note**: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
**hint**: See PEP 668 for the detailed specification.
Python 3 library install failed!
If problems persist, visit forums.pimoroni.com for support
**pi@raspberrypi**:**~/Pimoroni/automationhat $** sudo apt install python3-automationhat
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
python3-automationhat is already the newest version (0.2.0).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
When I check the Pimoroni/automationhat/ folder, there are no example files. I created input.py:
#!/usr/bin/env python3
import automationhat
if automationhat.is_automation_hat():
automationhat.light.power.write(1)
print(automationhat.input.read())
print(automationhat.analog.read())
time.sleep(0.5)
This does seem to work, but results in inconsistent input values. Also, the signal is connected on ADC 1, but the value reads on ADC 2 in the above script. This seems consistent as I connected 5v direct to ADC 2 and it shows up on ADC 3
Physically, I have 5V from the hat connected across a voltage divider with a potentiometer as the lower resister to allow changing the input (5v - 10k ohm - v output - 10k ohm pot - ground). We have verified with a multimeter that we are getting values in the 2.5v range depending on the pot position.
When I manually enter commands into the interpreter I get interesting results. The first read of the analog results in a good value, but each subsequent read results in 0.02, 4.4, 5.3, or sometimes the correct value.
Code used:
import automationhat as hat
hat.analog.one.read()
The lights on the hat are off until the first command. they are then on consistently until I exit the interpreter.
We have also tried running the Node-red module with similar results. Wildly varying values are received, but generally 0.02, 4.4, 5.3, or the actual value. In this case, the ADC number also seems to be offset.
