I received my Badger2040 recently and I think it might be malfunctioning.
When I press the c button to open the app in the 3rd column, the middle app is opened instead.
In the “list” app, pressing c checks an item, as does pressing b.
Both the combos a+b and a+c will close an app.
This happened out of the box, so I flashed w/ latest firmware (pimoroni-badger2040-v0.0.4-micropython-with-badger-os.uf2), but I’m still experiencing the same issue.
My guess would be that two of the pins on the RP2040 are being connected that shouldn’t be - if you have a good camera or a magnifying glass you should be able to peer at the RP2040 on the rear of your Badger (it’s a big square chip with a raspberry printed on it) and see if you can spot any strings of solder bridging between the pads?
I couldn’t spot any obvious shorts, but some pins were much much closer together than others. I checked with a very cheap microscope and was able to get some decent pictures with an iPad as well.
I made sure to triple check pins 15, 16, 17 (GPIO 12, 13, 14) in the bottom left corner that correspond to BUTTON_A, BUTTON_B, and BUTTON_C.
Due to new user limits, I’ve embedded a single image that clearly shows the pins referenced above, and I’ve created a gist that contains images of the other sides of the board.
I can’t spot anything that looks obviously awry there - if you have a multimeter handy you could check the pins in question for shorts? Sometimes there can be tiny strings of solder between the pins causing connections where they shouldn’t - holding a hot iron between (not touching) the solder joints in question usually gets rid of these.
If you don’t have any luck figuring out what’s causing the problem, no worries - sounds very much like some sort of hardware fault to me so support should be able to sort you out with a replacement: Submit a ticket : Pimoroni
