I’m using pimoroni-badger2040-1.19.7-micropython.uf2 on my badger2040. When I try to set the system speed to, for example, SYSTEM_FAST using the following docs:
I get this error message
AttributeError: ‘Badger2040’ object has no attribute ‘system_speed’
Is the system speed setting not part of release 1.19.7 ?
my bad, I think. I was using it as
import badger2040
display = badger2040.Badger2040()
badger = badger2040.Badger2040()
When using it like this:
import badger2040
badger2040.system_speed(badger2040.SYSTEM_FAST)
It does work but I’m not really sure why as the following is the same for the screen update speed, similar format and this does work.
import badger2040
display.update_speed(badger2040.UPDATE_FAST)
