Battery power for Pi Zero 2 W + 7.3" e-ink display
Hi everyone,
I have a Raspberry Pi Zero 2 W driving a 7.3" e-ink display. Currently, the display refreshes once every hour via a script, and everything works fine when powered from the wall.
For convenience, I’d like this setup to run on battery, ideally autonomously for days.
Does anyone have ideas for a battery setup or wiring solution?
I’m looking for something that:
  • works with the Pi Zero 2 W
  • can provide enough current for both the Pi and the display
  • allows easy recharging
  • ideally can keep the Pi powered while charging the battery
Thanks in advance for any advice or experiences!
Read pi-e-ink-daily/Inky-Impression-Frame at master · bablokb/pi-e-ink-daily · GitHub and be sure to scroll down to skip all the sections about the frame itself (the battery part follows).
What I basically use is a LiPo and a boost-converter with an enable pin. The LiPo (an 18650) sits in the bottom of the frame, connected to a TP4046 LiPo charger:
I am doing this with an Inky Impression 7.3” and a Witty Pi L3v7 hat on a Zero 2W. The battery is a 6600mAh from Adafruit. This works great as long as you do the SPI speed fix noted at Inky Impression 13.3" + Witty Pi + Raspberry Pi Zero W2 not working
Very nice setup, thanks for sharing. The next thing you want to do is optimize uptime. Current draw is mostly dominated by uptime, and you can do a lot to speed up boot-time. I had written an article about what to do. It is more than five years old but most of it is still valid. Back then, I managed to bring down boot times of a Pi-Zero from 30 to 5 seconds.
The article is in German, but I guess some translation tool will happily swallow it. Anyhow, if you have questions, just ask.
Thank you, I’ll give this a read. My current boot time does seem quite long
