and did the following.
pi@raspberrypi:~ $ python3 -m venv ~/my_virtual_env
pi@raspberrypi:~ $ source ~/my_virtual_env/bin/activate
(my_virtual_env) pi@raspberrypi:~ $ sudo apt install python3-dev
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
python3-dev is already the newest version (3.11.2-1+b1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
(my_virtual_env) pi@raspberrypi:~ $ pip install gpiod-2.0.1.tar.gz
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Processing ./gpiod-2.0.1.tar.gz
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: gpiod
Building wheel for gpiod (pyproject.toml) ... done
Created wheel for gpiod: filename=gpiod-2.0.1-cp311-cp311-linux_aarch64.whl size=93876 sha256=2459abc3eebecfea81ac658c847cd5ce2226fc2188e57ed7d35225d4169f3e19
Stored in directory: /home/pi/.cache/pip/wheels/88/37/59/bd1f565745b127d16180eb2475aba0b290cc4eaef2c34cde26
Successfully built gpiod
Installing collected packages: gpiod
Attempting uninstall: gpiod
Found existing installation: gpiod 2.0.1
Uninstalling gpiod-2.0.1:
Successfully uninstalled gpiod-2.0.1
Successfully installed gpiod-2.0.1
(my_virtual_env) pi@raspberrypi:~ $ git clone https://github.com/pimoroni/blinkt -b repackage
Cloning into 'blinkt'...
remote: Enumerating objects: 1425, done.
remote: Counting objects: 100% (243/243), done.
remote: Compressing objects: 100% (137/137), done.
remote: Total 1425 (delta 109), reused 184 (delta 78), pack-reused 1182
Receiving objects: 100% (1425/1425), 411.36 KiB | 3.49 MiB/s, done.
Resolving deltas: 100% (843/843), done.
(my_virtual_env) pi@raspberrypi:~ $ cd blinkt
(my_virtual_env) pi@raspberrypi:~/blinkt $ pip install .
Processing /home/pi/blinkt
Requirement already satisfied: gpiod in /home/pi/my_virtual_env/lib/python3.11/site-packages (from blinkt==0.1.2) (2.0.1)
Requirement already satisfied: gpiodevice>=0.0.2 in /home/pi/my_virtual_env/lib/python3.11/site-packages (from blinkt==0.1.2) (0.0.3)
Building wheels for collected packages: blinkt
Building wheel for blinkt (pyproject.toml) ... done
Created wheel for blinkt: filename=blinkt-0.1.2-py3-none-any.whl size=10539 sha256=c3e37203fe386081df943c7264b25ab7e022ed9954080f389f72c5cbbcf14271
Stored in directory: /tmp/pip-ephem-wheel-cache-h7e295u4/wheels/1f/15/39/e27ca04201b69df7270a606a5d1fc5d9ea73eccd561ad00e2c
Successfully built blinkt
Installing collected packages: blinkt
Attempting uninstall: blinkt
Found existing installation: blinkt 0.1.2
Uninstalling blinkt-0.1.2:
Successfully uninstalled blinkt-0.1.2
Successfully installed blinkt-0.1.2
(my_virtual_env) pi@raspberrypi:~/blinkt $ pip3 install .
Stored in directory: /tmp/pip-ephem-wheel-cache-ac2aklsj/wheels/1f/15/39/e27ca04201b69df7270a606a5d1fc5d9ea73eccd561ad00e2c
(my_virtual_env) pi@raspberrypi:~/blinkt $ cd examples
(my_virtual_env) pi@raspberrypi:~/blinkt/examples $ python3 cpu_temp.py
The cpu_temp.py file worked from command line. Could not get it to run from Thony though? blinkt has no attribute… error messages.
How do I get it to run on bootup? I guessing I have to load the virtual environment first, then run my py file? I normally launch my py file via crontab.
