Bme 680 python script not working
Hi there,
I am new to the forum and to the raspberry pi stuff and for my first tryout I bought a bme680 sensor.
So far I couldn’t get any readings from it, althoug I used to code from the github side. Now every time I try to run the python 3 code I get an error.
Estimate indoor air quality
Runs the sensor for a burn-in period, then uses a
combination of relative humidity and gas resistance
to estimate indoor air quality as a percentage.
Press Ctrl+C to exit
File “/home/pi/bme680/examples/indoor-air-quality.py”, line 16, in
sensor = bme680.BME680()
File “build/bdist.linux-armv7l/egg/bme680/init.py”, line 25, in init
self.chip_id = self._get_regs(CHIP_ID_ADDR, 1)
File “build/bdist.linux-armv7l/egg/bme680/init.py”, line 285, in _get_regs
return self._i2c.read_byte_data(self.i2c_addr, register)
IOError: [Errno 121] Remote I/O error
I am not shure if it is from a wrong ic2 because I didn’t solder the pins like in the description which I thought would only be necessary if I use a second one.
I I try to run the second programm I get this error.
=============== RESTART: /home/pi/bme680/examples/read-all.py ===============
File “/home/pi/bme680/examples/read-all.py”, line 6, in
Thanks for the help in advance.
Vadi
We got you fixed up in Discord, right? :-) I’ll mark this as solved and close.
