BME688 sensor libraries not working
Hi, I’ve used Pimoroni enviro+ boards without much problem, but I am finding the BME688 boards just don’t work. I do have pi3g addon board that worked for a while, but the Bosch libraries for that are now failing. I was concerned with the move to Bosch, pretending that a sensor that can tell the difference between coffee and fresh air is any use is a stretch. I also have the Bosch board with 8 sensors on, that can ‘learn’ what coffee smells like much faster, but I suspect that will now have stopped working. I had already decided that multiple interacting sensors on a small chip was a ridiculous idea, I’m now going back to individual sensors that can be separated sufficiently to avoid the massive problem of trying to compensate for interdependence on 4 sensors. If anyone has BSEC_2.0.6.1_Generic_Release_04302021/algo/normal_version/bin/RaspberryPi/PiThree_ArmV6, running I’d like to hear about it.
I realise this is an old post, however for those who might be searching….
The PI3G wrapper on BSEC2 works with all of the BME688 sensor modules from Adafruit, Pimoroni, PI3G, etc. There is support all versions of BSEC2 (latest is for BSEC v2.6.1.0), and you can find the releases on GitHub here: mcalisterkm (Keith McAlister) · GitHub
As this is a wrapper for BSEC you have access to all the AI features.
Regards
Keith
