Can the Inky Impression boards be used with MicroPython?
I have something on an older Inky Frame that I’d like to update to the new 13.3" Inky Impression. I see the Impression getting-started guide discusses Rasbian. I don’t want to deal with a whole OS (that’s my day job!). Can I just use MicroPython?
Theoretically, yes. I use the Inky-Impressions with CircuitPython running on a Pico-W. You need two things:
  • an adapter or some smart wiring mapping the pins of the Inky to your device
  • a software driver for MicroPython
For the large 13.3" you would certainly opt for a device with a lot of RAM, e.g. the Pico Plus 2W.
For the adapter, you probably can use this one: Pico to Pi HAT - The Pi Hut. I haven’t used it, so there is no guarantee that it works - you should definitely check the pin-mapping first.
Since Pimoroni is planning to also make a new generation of Inky-Frames with the new displays, you can expect that the MP-drivers will pop up some day too. Until then, you are probably on your own.
Nice, thanks. Are the pins documented somewhere?
In the meantime, I’ve got it going using a Pi Zero, but it seems a horrible shame to use an e-ink display with a device always sucks power. I want something that can wake up once a day, update the screen, then power off.
There is a link on the product page to the schematic, there you will find the used pins. Another option is https://pinout.xyz, but this only documents an old Inky. But I think the pins haven’t changed.
When I started with the Inky-Impression, I had the same goal. You can have a look at my projects here: GitHub - bablokb/pi-e-ink-daily: Display Daily Agenda on an E-Ink Display and here: GitHub - bablokb/pcb-pi-batman: A simple hat for battery based Pi projects
That worked well with the Pi-Zero, but compared with a Pico, it still sucks too much power. A Pi-Zero2-W is probably the best compromise, because it boots faster and the uptime is the main driver of energy consumption.
Oooh, I found GitHub - bablokb/circuitpython-inky: CircuitPython Drivers for various Pimoroni E-Ink Displays. That looks promising!
Yes, this is for CircuitPython, not MicroPython. I ported the Pimoroni Pi-driver for the 7.3" Spectra6 display to CircuitPython. I don’t have the 13.3", so there is no driver available yet but porting should be very similar.
