Hi, I currently have a problem caused by a potential conflict between the BCM pin 24 used in my phat beat board and an OLED library that uses SPI pins including BCM24.
This is because when I ran the demo script of the OLED library, I get:
pi@raspberrypi:~/luma.examples $ python examples/demo.py --display ssd1351 --width 128 --height 128 --interface spi --spi-bus-speed 8000000
Version: luma.oled 2.3.1 (luma.core 1.3.0)
Display: ssd1351
Interface: spi
Dimensions: 128 x 128
/usr/local/lib/python2.7/dist-packages/luma/core/interface/serial.py:164: RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
self._gpio.setup(pin, self._gpio.OUT)
Upon checking https://pinout.xyz/pinout/phat_beat#, I think that BCM24 is the pin that is causing the conflict potentially.
Could anyone advise me on how I can modify the installed library of phat beat such that BCM 24 pin gets rerouted to another pin e.g. BCM 0?
