I am using a Raspberry Pi 3B+ to display a website/websites on a screen, and recently attached a Pimoroni Button-Shim.
Since writing some Python code (below) I have had the buttons working, but the Raspberry Pi seems to freeze after about 18 hours. I’ve never been around to see it happen, but on returning it has now been frozen three times.
It never did this before I wrote this code, and assume it probably has something to do with poorly written code, rather than the soldering itself.
I have a bit of experience with Python, but never with continuously running programs, and handlers are a new concept for me.
The code is Python 3, using the library provided by Pimoroni, and starts via LXDE-pi/autostart.
If you have any idea on how to help that would be greatly appreciated, I’ve had a bit of a google, but don’t really know any resources or what to type in to find a solution.
It works immediately on hard reboot, and I’m not really sure where to go next.
#!usr/bin/python3
import buttonshim
from time import sleep
import os
sleep(10)
os.system('chromium-browser --noerrdialogs --incognito --kiosk url1')
buttonshim.set_pixel(221,36,33)
@buttonshim.on_press(buttonshim.BUTTON_A)
def handler(button, pressed):
os.system('pkill chromium-browser')
os.system('chromium-browser --noerrdialogs --incognito --kiosk https://www.nytimes.com')
buttonshim.set_pixel(33, 106, 224)
@buttonshim.on_press(buttonshim.BUTTON_B)
buttonshim.set_pixel(0xFF, 0x00, 0xFF)
@buttonshim.on_press(buttonshim.BUTTON_C)
os.system('vcgencmd display_power 0')
@buttonshim.on_press(buttonshim.BUTTON_D)
os.system('vcgencmd display_power 1')
sleep(10)
The code works as expected at the start, but eventually doesn’t.
