I’m looking at getting the Inventor board to output high-quality sound (audio/music) for simple sound effects. Any suggestions for how could I achieve this?
I am using MicroPython so it would need to be I2S compatible. Even better if I can use the Audio out of the Inventor board.
From my research the board is only capable of playing simple sounds.
For I2S, you need three pins. Probably GP0-GP2 will do. You can connect these pins to an audio DAC. I like the MAX98357A, PCM5102A or UDA1334A. The first one is a mono amp and you can attach a speaker directly to the board. The second usually has a 3.5mm plug and gives stereo line-out (i.e. you need an additional amplifier for that). The same is true for the third DAC.
Edit: you asked for “high-quality sound for simple sound effects”. This is a bit contradictory. Just for completeness: the Inventor 2040W has a builtin PAM8301, which is an amplifier and uses a single PWM-pin for audio. I bet you probably won’t notice the difference unless you use a stereo line-level I2S-DAC combined with a good amp and speakers. So unless you really need “high-quality sound”, I would keep it simple and stick to that.
