==================== RESTART: /home/pi/Scripts/New/1.9.py ====================
File "/home/pi/Scripts/New/1.9.py", line 196, in <module>
menu.redraw()
File "/usr/local/lib/python3.5/dist-packages/dot3k/menu.py", line 476, in redraw
self.current_value().redraw(self)
File "/home/pi/Scripts/New/1.9.py", line 145, in redraw
text=self.get_next_option()
File "/usr/local/lib/python3.5/dist-packages/dot3k/menu.py", line 431, in write_option
current_row += text
TypeError: Can't convert 'NoneType' object to str implicitly
import sys
sys.path.append ('/usr/local/lib/python2.7/dist-packages')
sys.path.append('/home/pi/Pimoroni/displayotron/examples')
sys.path.append('/home/pi/.local/lib/python2.7/site-packages')
import subprocess
import threading
import dothat.backlight as backlight
import dothat.lcd as lcd
import dothat.touch as nav
from dot3k.menu import Menu, MenuOption
from time import sleep
import datetime
from plugins.clock import Clock
from plugins.graph import IPAddress, GraphTemp, GraphCPU, GraphNetSpeed, GraphSysReboot, GraphSysShutdown
from plugins.text import Text
from plugins.utils import Backlight, Contrast
from astral import Astral
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
GPIO.setup(13,GPIO.OUT)
GPIO.setup(5,GPIO.OUT)
import schedule
class lights(MenuOption):
def __init__(self):
self._mode = 0
self._message = ''
self._timeout = 0
self._status = False
self._auto = True
self._sun_rise = None
self._sun_set = None
self._current_status = 'off'
self.selected_option = 0
self.options = [
'Daylights',self.daylights_on(),
'Nightlights',self.nightlights_on(),
'LightsAuto',self.auto_on(),
'Dayset',
'Offset',
'Nightset'
MenuOption.__init__(self)
def display_message(self, message, timeout=1):
self._message = message
self._timeout = time.time() + timeout
self._mode = 1
def next_option(self):
self.selected_option = (self.selected_option + 1) % len(self.options)
def prev_option(self):
self.selected_option = (self.selected_option - 1) % len(self.options)
def daylights_on(self): #Activates Daylights
self._current_status = 'day'
GPIO.output(13,0)
GPIO.output(5,1)
GPIO.output(13,1)
self._status = True
self.display_message("DayLights: On", 1)
def nightlights_on(self): #Activates Nightlights
self._current_status = 'night'
GPIO.output(13,0)
GPIO.output(5,1)
GPIO.output(13,0)
self._status = True
self.display_message("NightLights: On", 1)
def lights_off(self): # Deactivates any light mode
GPIO.output(5,0)
self.display_message("Lights: Off", 1)
def light_toggle(self): # Toggles Between Day/Night Modes
if (GPIO.input(13) == True):
else:
self.daylights_on()
def auto_on(self): # Sets an automatic timer to activate lights
self._auto = True
self.display_message("Auto: On", 1)
def auto_off(self): # Sets an automatic timer to dectivate lights
self._auto = False
self.display_message("Auto: Off", 1)
We'll need to override the up/down control methods
to call our next/prev methods
def up(self):
self.prev_option()
def down(self):
self.next_option()
And these are some handy functions for getting the prev/next/current
option text for display on the menu.
def get_current_option(self):
return self.options[self.selected_option]
def get_next_option(self):
return self.options[(self.selected_option + 1) % len(self.options)]
def get_prev_option(self):
return self.options[(self.selected_option - 1) % len(self.options)]
When the menu is redrawn, it calls your plugins
redraw method and passes an instance of itself.
def redraw(self, menu):
menu.write_option(
row=0,
margin=1,
text=self.get_prev_option()
menu.write_option(
row=1,
margin=1,
icon='>',
text=self.get_current_option()
menu.write_option(
row=2,
margin=1,
return
menu = Menu(
structure={
'Power Options': {
'Reboot':GraphSysReboot(),
'Shutdown':GraphSysShutdown(),
'Aquarium': {
'Lighting': {
'Control': lights(),
'Clock': Clock(backlight),
'Status': {
'IP': IPAddress(),
'CPU': GraphCPU(backlight),
'Temp': GraphTemp()
'Settings': {
'Display': {
'Contrast': Contrast(lcd),
'Backlight': Backlight(backlight)
lcd=lcd,
@nav.on(nav.UP)
def handle_up(pin):
menu.up()
@nav.on(nav.DOWN)
def handle_down(pin):
menu.down()
@nav.on(nav.RIGHT)
def handle_right(pin):
menu.right()
@nav.on(nav.LEFT)
def handle_LEFT(pin):
menu.left()
@nav.on(nav.BUTTON)
def handle_BUTTON(pin):
menu.select()
while 1:
menu.redraw()
time.sleep(0.01)
heres the menu package
import time, os, atexit, sys
from collections import OrderedDict
import threading
if sys.version_info[0] >= 3:
import configparser as ConfigParser
else:
import ConfigParser
_MODE_NAV = 'navigate'
_MODE_ADJ = 'adjust'
_MODE_TXT = 'entry'
class MenuIcon():
arrow_left = [0,0,8,24,8,0,0,0]
arrow_right = [0,0,2,3,2,0,0,0]
arrow_up = [0,4,14,0,0,0,0,0]
arrow_down = [0,0,0,0,0,14,4,0]
arrow_left_right = [0,0,10,27,10,0,0,0]
arrow_up_down = [0,4,14,0,0,14,4,0]
play = [0,24,30,31,30,24,0,0]
pause = [0,27,27,27,27,27,0,0]
back = [0,8,30,9,1,1,14,0]
bar_left = [0,3,2,2,2,2,3,0]
bar_right = [0,24,8,8,8,8,24,0]
bar_full = [0,31,0,31,31,0,31,0]
bar_empty = [0,32,0,0,0,0,32,0]
class StoppableThread(threading.Thread):
def __init__(self):
threading.Thread.__init__(self)
self.stop_event = threading.Event()
self.daemon = True
def start(self):
if self.isAlive() == False:
self.stop_event.clear()
threading.Thread.start(self)
def stop(self):
if self.isAlive() == True:
# set event to signal thread to terminate
self.stop_event.set()
# block calling thread until thread really has terminated
self.join()
class AsyncWorker(StoppableThread):
def __init__(self, todo):
StoppableThread.__init__(self)
self.todo = todo
def run(self):
while self.stop_event.is_set() == False:
if self.todo() == False:
break
class Menu():
This class accepts a list of menu items,
Each key corresponds to a text item displayed on the menu
Each value can either be:
* A nested list, for a sub-menu
* A function, which is called immediately on select
* A class derived from MenuOption, providing interactive functionality
def __init__(self, *args, **kwargs):
structure, lcd, idle_handler = None, idle_time = 60
self.menu_options = OrderedDict()
self.lcd = None
self.idle_handler = None
self.input_handler = None
self.idle_time = 60*1000
self.config_file = 'dot3k.cfg'
# Track displayed text for auto-scroll
self.last_text = ['','','']
self.last_change = [0,0,0]
if len(args) > 0 and not args[0] == None:
self.menu_options = args[0]
if len(args) > 1:
self.lcd = args[1]
if len(args) > 2:
self.idle_handler = args[2]
if len(args) > 3:
self.idle_time = args[3]*1000
if 'structure' in kwargs.keys() and not kwargs['structure'] == None:
self.menu_options = kwargs['structure']
if 'lcd' in kwargs.keys():
self.lcd = kwargs['lcd']
if 'idle_handler' in kwargs.keys():
self.idle_handler = kwargs['idle_handler']
if 'idle_time' in kwargs.keys():
self.idle_time = kwargs['idle_time']*1000
if 'input_handler' in kwargs.keys():
self.input_handler = kwargs['input_handler']
if 'config_file' in kwargs.keys():
self.config_file = kwargs['config_file']
self.list_location = []
self.current_position = 0
self.idle = False
self.mode = _MODE_NAV
self.config = ConfigParser.ConfigParser()
self.config.read([self.config_file, os.path.expanduser('~/.' + self.config_file)])
if type(self.menu_options) is dict or type(self.menu_options) is OrderedDict:
self._setup_menu(self.menu_options)
self.last_action = self.millis()
self._thread = AsyncWorker(self._update)
atexit.register(self.save)
def run(self):
self._thread.start()
atexit.register(self.stop)
def stop(self):
self._thread.stop()
def _update(self):
self.redraw()
time.sleep(0.05)
def millis(self):
return int(round(time.time() * 1000))
def add_item(self, path, handler):
if not type(path) is list:
path = path.split('/')
loc = self.menu_options
last = path.pop()
while len(path) > 0:
key = path.pop()
if not key in loc:
loc[key] = OrderedDict()
loc = loc[key]
loc[last] = handler
if isinstance(loc[last],MenuOption):
loc[last].setup(self.config)
def save(self):
with open('dot3k.cfg', 'wt', encoding='utf-8') as configfile:
self.config.write(configfile)
else:
with open('dot3k.cfg', 'wb') as configfile:
print('Config saved to dot3k.cfg')
def _setup_menu(self, menu):
for key in menu:
value = menu[key]
if type(value) is dict or type(value) is OrderedDict:
self._setup_menu(value)
elif isinstance(value,MenuOption):
value.setup(self.config)
def current_submenu(self):
Traverse the list of indexes in list_location
and find the relevant nested listionary
menu = self.menu_options
for location in self.list_location:
menu = menu[list(menu.keys())[location]]
return menu
def current_value(self):
return self.current_submenu()[self.current_key()]
def current_key(self):
Convert the integer current_position into
a valid key for the currently selected listionary
return list(self.current_submenu().keys())[self.current_position]
def next_position(self):
position = self.current_position + 1
position %= len(self.current_submenu())
return position
def previous_position(self):
position = self.current_position - 1
return position
def select_option(self):
Navigate into, or handle selected menu option accordingly
if type(self.current_value()) is dict or type(self.current_value()) is OrderedDict:
self.list_location.append( self.current_position )
elif isinstance(self.current_value(),MenuOption):
self.mode = _MODE_ADJ
self.current_value().begin()
elif callable(self.current_submenu()[self.current_key()]):
self.current_submenu()[self.current_key()]()
Decrement the option pointer,
select previous menu item
self.current_position = self.previous_position()
Increment the option pointer,
select next menu item
self.current_position = self.next_position()
def exit_option(self):
Exit current submenu and restore position
in previous menu
if len(self.list_location) > 0:
self.current_position = self.list_location.pop()
def start_input(self):
if self.input_handler == None:
return False
self.current_value().text_entry = False
self.input_handler.begin()
self.input_handler.set_value(self.current_value().initial_value())
self.input_handler.set_prompt(self.current_value().input_prompt())
self.mode = _MODE_TXT
def finish_input(self):
if self.input_handler.cancel_input:
self.current_value().cancel_input()
self.input_handler.cancel_input = False
self.input_handler.cleanup()
else:
self.current_value().receive_input(self.input_handler.get_value())
def select(self):
Handle "select" action
if self.idle:
self.idle = False
self.idle_handler.cleanup()
self.idle_handler.idling = False
return True
if self.mode == _MODE_NAV:
self.select_option()
elif self.mode == _MODE_ADJ:
# The "select" call must return true to exit the adjust
if self.current_value().select():
elif self.mode == _MODE_TXT:
if self.input_handler.select():
self.finish_input()
def cancel(self):
if self.idle:
self.idle = False
return True
self.exit_option()
self.current_value().cleanup()
def up(self):
if self.idle:
self.idle = False
return True
self.prev_option()
self.current_value().up()
self.input_handler.up()
def down(self):
if self.idle:
self.idle = False
return True
self.next_option()
self.current_value().down()
self.input_handler.down()
def left(self):
if self.idle:
self.idle = False
return True
self.exit_option()
if not self.current_value().left():
self.input_handler.left()
def right(self):
if self.idle:
self.idle = False
return True
self.current_value().right()
self.input_handler.right()
def clear_row(self,row):
self.lcd.set_cursor_position(0,row)
self.lcd.write(' '*self.lcd.COLS)
def write_row(self,row,text):
while len(text) < self.lcd.COLS:
text += ' '
self.lcd.write(text[0:self.lcd.COLS])
#def write_option(self,row,text,icon=' ',margin=1):
def write_option(self, *args, **kwargs):
row = 0
text = ''
icon = ''
margin = 0
scroll = False
scroll_padding = ' '
scroll_delay = 2000
scroll_repeat = 10000
scroll_speed = 200
if len(args) > 0:
row = args[0]
if len(args) > 1:
text = args[1]
if len(args) > 2:
icon = args[2]
if len(args) > 3:
margin = args[3]
if 'row' in kwargs.keys():
row = kwargs['row']
if 'text' in kwargs.keys():
text = kwargs['text']
if 'icon' in kwargs.keys():
icon = kwargs['icon']
if 'margin' in kwargs.keys():
margin = kwargs['margin']
if 'scroll' in kwargs.keys() and kwargs['scroll'] == True:
scroll = True
if 'scroll_speed' in kwargs.keys():
scroll_speed = kwargs['scroll_speed']
if 'scroll_repeat' in kwargs.keys():
scroll_repeat = kwargs['scroll_repeat']
if 'scroll_delay' in kwargs.keys():
scroll_delay = kwargs['scroll_delay']
if 'scroll_padding' in kwargs.keys():
scroll_padding = kwargs['scroll_padding']
if icon == None:
icon = ''
if margin == None:
margin = 0
current_row = ''
if( self.last_text[row] != text ):
self.last_text[row] = text
self.last_change[row] = self.millis()
if scroll:
text += scroll_padding
if scroll and self.millis() - self.last_change[row] > scroll_delay:
pos = int(((self.millis() - self.last_change[row] - scroll_delay) / scroll_speed) % len(text))
text = text[pos:]+text[:pos]
if pos == len(text)-1:
self.last_change[row] = self.millis() + scroll_repeat
current_row += icon
while len(current_row) < margin:
current_row += ' '
current_row += text
self.write_row(row,current_row)
def get_menu_item(self, index):
return list(self.current_submenu().keys())[index]
def redraw(self):
if self.can_idle() and isinstance(self.idle_handler,MenuOption):
if self.idle == False:
self.idle_handler.idling = True
self.idle_handler.begin()
self.idle = True
self.idle_handler.redraw(self)
return False
self.write_option(
row=1,
text=self.get_menu_item(self.current_position),
icon=chr(252),
margin=1
if len(self.current_submenu()) > 2:
self.write_option(
row=0,
text=self.get_menu_item(self.previous_position()),
margin=1
else:
self.clear_row(0)
if len(self.current_submenu()) > 1:
self.write_option(
row=2,
text=self.get_menu_item(self.next_position()),
margin=1
else:
self.clear_row(2)
# Call the redraw function of the endpoint Class
if self.current_value().text_entry:
self.start_input()
self.input_handler.redraw(self)
def can_idle(self):
if self.millis() - self.last_action >= self.idle_time:
return True
if self.mode == _MODE_ADJ and self.current_value().can_idle:
return True
return False
class MenuOption():
def __init__(self):
self.idling = False
self.can_idle = False
self.config = None
self.text_entry = False
These helper functions let you start
the input_handler of the parent menu
and receive the text that the user inputs
def initial_value(self):
# Return a value to start with
return ''
def receive_input(self, value):
# Return false to reject input
return True
def request_input(self):
self.text_entry = True
def cancel_input(self):
# Called if input is cancelled by handler
pass
def input_prompt(self):
return 'Input text:'
These helper functions are for
input handler plugins
def set_value(self, value):
pass
def get_value(self):
return ''
def set_prompt(self, value):
pass
def millis(self):
def up(self):
pass
def down(self):
pass
def left(self):
pass
def right(self):
pass
def select(self):
# Must return true to allow exit
return True
def begin(self):
pass
pass
def setup(self, config):
self.config = config
def cleanup(self):
# Undo any backlight or other changes
pass
def set_option(self, section, option, value):
if self.config != None:
if not section in self.config.sections():
self.config.add_section(section)
self.config.set(section, option, value)
def get_option(self, section, option, default = None):
if option in self.config.options(section):
return self.config.get(section, option)
elif default == None:
return False
else:
self.config.set(section, option, str(default))
return default
