Here’s a “toy” music player written using Python, and GStreamer. On the Display-o-Tron LCD, it will show artist name, title and time. While playing, the music is analyzed ala moodbar to turn the sound into a RGB triplet. The resulting colors are scrolled along the backlight. It’s pretty nice! :)
I’m missing the equipment for a proper video. Feel free to make one!
#!/usr/bin/env python3
# dot_mood_player.py:
# GStreamer-based player that will scroll colors on the Display-o-Tron
# depending on the music “mood”.
# On Debian:
# # apt install --no-install-recommends \
# python3-gi gir1.2-gstreamer-1.0 gir1.2-gst-plugins-base-1.0 \
# gstreamer1.0-plugins-base gstreamer1.0-plugins-good \
# gstreamer1.0-alsa
# Usage:
# ./dot_mood_player.py <audio-file>
# Copyright © 2016 Lunar
# This work is free. You can redistribute it and/or modify it under the
# terms of the Do What The Fuck You Want To Public License, Version 2,
# as published by Sam Hocevar. See http://www.wtfpl.net/ for more details.
import os
import os.path
import sys
import subprocess
import itertools
import re
import atexit
import signal
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from dothat import backlight, lcd
SPECTRUM_INTERVAL = 100000000 # 0.1 second
SPECTRUM_MAGNITUDE_THRESHOLD = -60 # dB
LED_COUNT = 6
MINIMUM_BACKLIGHT = 1
DISPLAY_WIDTH = 16
ELLIPSIS_CHAR = [
0b00000
, 0b00000
, 0b00000
, 0b00000
, 0b00000
, 0b00000
, 0b10101
, 0b00000
class Player(object):
def __init__(self, media_path):
self._media_path = media_path
# Initialize with first lights at the center
self._leds = [(0, 0, 0)] * LED_COUNT
self._duration = None
self._playing = False
self._label = ''
self._label_position = None
self.setup_pipeline()
bus = self._pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message::tag", self.handle_bus_message_tag_event)
bus.connect("message::async-done", self.handle_bus_async_done)
bus.connect("message::duration-changed", self.handle_bus_duration_changed)
bus.connect("message::element", self.handle_element)
self.init_display()
def setup_pipeline(self):
pipeline = '''filesrc location="{location}" ! decodebin ! audioconvert !
spectrum bands=3 post-messages=true message-magnitude=true threshold={threshold} interval={interval} !
autoaudiosink'''.format(location=self._media_path, threshold=SPECTRUM_MAGNITUDE_THRESHOLD, interval=SPECTRUM_INTERVAL)
self._pipeline = Gst.parse_launch(pipeline)
def scroll_color(self, *color):
self._leds = self._leds[1:] + [color]
for led, colors in enumerate(self._leds):
backlight.single_rgb(led, *colors, auto_update=False)
backlight.update()
def update_backlight(self, r, g, b):
if (r + g + b) / 3 < MINIMUM_BACKLIGHT:
r, g, b = [MINIMUM_BACKLIGHT] * 3
self.scroll_color(r, g, b)
def transition_backlight(self, color_iterator):
try:
self.move_leds(*next(color_iterator))
return True
except StopIteration:
return False
def handle_element(self, bus, message):
if message.get_structure().get_name() == 'spectrum':
self.handle_spectrum(bus, message)
WORKAROUND_RE = re.compile(r'magnitude=\(float\){ ([0-9.-]+), ([0-9.-]+), ([0-9.-]+) };')
def handle_spectrum(self, bus, message):
# Ugly workaround, although thanks Christian Leichsenring
# http://thread.gmane.org/gmane.comp.video.gstreamer.devel/56869
s = message.get_structure().to_string()
m = Player.WORKAROUND_RE.search(s)
if not m:
return
magnitudes = list(map(float, m.groups()))
colors = [ int((SPECTRUM_MAGNITUDE_THRESHOLD - magnitude) * 255 / SPECTRUM_MAGNITUDE_THRESHOLD) for magnitude in magnitudes ]
self.update_backlight(*colors)
def init_display(self):
lcd.clear()
lcd.create_char(1, ELLIPSIS_CHAR)
backlight.rgb(64, 64, 64)
def update_label(self, tags):
if tags['artist'] and tags['title']:
self.label = '{artist} - {title}'.format(**tags)
elif tags['title']:
self.label = tags['title']
else:
self.label = os.path.basename(self._media_path)
@property
def label(self):
return self._label
@label.setter
def label(self, value):
self._label = value
self._label_position = itertools.cycle(itertools.chain(itertools.repeat(0, 10), range(len(self._label))))
def update_display(self):
lcd.set_cursor_position(0, 0)
if len(self.label) > DISPLAY_WIDTH:
s = self.label[next(self._label_position):]
if len(s) > DISPLAY_WIDTH:
lcd.write('{}\1'.format(s[:DISPLAY_WIDTH - 1]))
else:
format_str = '{:%s}' % DISPLAY_WIDTH
lcd.write(format_str.format(s))
else:
lcd.write(self.label)
success, position = self._pipeline.query_position(Gst.Format.TIME)
if success:
position /= (1000 * 1000 * 1000) # get seconds
lcd.set_cursor_position(10, 2)
lcd.write('{:3d}:{:02d}'.format(int(position // 60), int(position % 60)))
return self._playing
def handle_bus_message_tag_event(self, bus, message):
taglist = message.parse_tag()
tags = { tag: taglist.get_string(tag)[1] for tag in ['artist', 'title'] }
self.update_label(tags)
def handle_bus_async_done(self, bus, message):
if not self._playing:
self._playing = True
self.update_duration()
GLib.timeout_add(250, self.update_display)
else:
def handle_bus_duration_changed(self, bus, message):
def play(self):
self._pipeline.set_state(Gst.State.PLAYING)
def update_duration(self):
success, duration = self._pipeline.query_duration(Gst.Format.TIME)
if success:
self._duration = duration
def cleanup():
lcd.clear()
backlight.off()
def main():
args = Gst.init(sys.argv)
player = Player(args[1])
atexit.register(cleanup)
GLib.idle_add(player.play)
main_loop = GLib.MainLoop()
try:
main_loop.run()
except KeyboardInterrupt:
main_loop.quit()
if __name__ == '__main__':
main()
