I have the older PiCade and the SD card I was using died. So I have to start over. Are the instructions for installing the drivers the same as the newer one?
I went here
And did a search for Picade. I “think” this is for the original Hat
It talks about the power button so I thought that was the new one. There is a folder called legacy-python-driver that I don’t know if I need that or not.
I “think” thats optional. I don’t own a Picade, old or new, just so you know.
I would try the one line installer and go from there
curl -sS https://get.pimoroni.com/picadehat | bash
I was wondering what the -sS parameters mean to curl. I could not find the answer?
I did a quick google for ‘curl command parameters’ and the first result was https://curl.haxx.se/docs/manpage.html which gives you all the arguments for curl, including s and S
It looks like -s silent and -S show error. Thanks I missed this.
