Fresh install of the library and dependancies for the Enviro+ hat on RPi
Everything else works out of the box (so far) but the LCD won’t work if I run it in python 3. The error is as follows:
pi@rpi:~/enviroplus-python/examples $ python3 lcd.py
File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 22, in <module>
from . import multiarray
File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 12, in <module>
from . import overrides
File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module>
from numpy.core._multiarray_umath import (
ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "lcd.py", line 3, in <module>
import ST7735
File "/usr/local/lib/python3.7/dist-packages/ST7735-0.0.4-py3.7.egg/ST7735/__init__.py", line 23, in <module>
import numpy as np
File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 140, in <module>
from . import core
File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 48, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.7 from "/usr/bin/python3"
* The NumPy version is: "1.19.4"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
The example runs fine in python2, but not python 3.x.
I installed via the single-line install as per the documentation and have rebooted. Any leads on getting numpy to play nice in py3?
