Yesterday I received my new enviro indoor and so I started with the provisioning of the device. I tried to connect it to my local 2,4G WIFI network, but my attempts were not successful. Everytime I was done with the configuration, I ended up with a red blinking LED on the enviro.
I upgraded to the most recent enviro software und also updated to the newest version of MicroPython.
This is how the startup of the enviro looks now in the log.txt file:
2000-01-01 00:01:50 [info / 127kB] > performing startup
2000-01-01 00:01:50 [debug / 125kB] - running Enviro 0.0.10, MicroPython v1.21.0, enviro v1.21.0 on 2023-10-06
2000-01-01 00:01:50 [info / 134kB] - wake reason: usb_powered
2000-01-01 00:01:50 [debug / 132kB] - turn on activity led
2000-01-01 00:01:50 [info / 131kB] > clock not set, synchronise from ntp server
2000-01-01 00:01:50 [info / 128kB] > connecting to wifi network 'Macroglossum stellatarum 2,4G'
2000-01-01 00:01:51 [error / 123kB] ! failed to connect to wireless network Macroglossum stellatarum 2,4G
2000-01-01 00:01:51 [error / 121kB] ! failed to synchronise clock
2000-01-01 00:01:51 [info / 119kB] > going to sleep
2000-01-01 00:01:51 [debug / 117kB] - clearing and disabling previous alarm
2000-01-01 00:01:51 [info / 115kB] - setting alarm to wake at 00:10am
2000-01-01 00:01:51 [info / 113kB] - shutting down
2000-01-01 00:01:52 [debug / 111kB] - on usb power (so can't shutdown). Halt and wait for alarm or user reset instead
I double and triple checked my WIFI password, but somehow it is still not working. I also tried to copy the password directly from the webpage of my router into the provisioning webpage of the enviro. After that I tried to copy the WIFI password to the config.py file with thonny. But I always end up with a red blinking LED.
This is how the network access details look in the config.py file:
My only guess is, that the wifi_ssid is somehow too long or not compatible? But I’ve never had any problems with many other different clients in my network. Is there any way to get a more verbose log why the connection to the wifi network is not possible? Do you have any further ideas?
Ok, I don’t think thats the issue then. I have a tone of Pi’s using WIFI, but I haven’t setup a Pico. If I get a chance, later on today I’ll grab a spare Pico W and try and connect it to my ISP supplied WIFI. It uses a long password like yours does. Mine has capital letters in it, and that caught me out, I had typed in lower case.
I ran the code below on my Pico W. It was Flashed with the Pimoroni PicoW uf2 file. It timed out on the first run, but connected just fine on any subsequent run.
You could try running it and see what happens?
import network
ssid = 'Wireless Network'
password = 'The Password'
wlan.active(True)
wlan.connect(ssid, password)
# Wait for connect or fail
max_wait = 10
while max_wait > 0:
if wlan.status() < 0 or wlan.status() >= 3:
break
max_wait -= 1
print('waiting for connection...')
time.sleep(1)
# Handle connection error
if wlan.status() != 3:
raise RuntimeError('network connection failed')
else:
print('connected')
status = wlan.ifconfig()
print( 'ip = ' + status[0] )
>>> %Run -c $EDITOR_CONTENT
connected
ip = 192.168.2.29
I had the same problem. Turns out the set up interface was truncating the password. You can see this if you rerun the setup, it will show truncated password.
The flash version that came with the Enviro hangs up trying to make the wifi connection. This prevented Thonny from connecting to the device.
I flashed the latest Enviro version which did not fix the problem but did allow access via Thonny. Edited main.py to fix the password and the wifi connected.
Thanks Curt, I was hoping somebody that had a Pico Enviro would chime in.
I have a Pico Enviro+ but it’s not running the custom Enviro firmware. It doesn’t even have a Pico W attached, just a Pico. I flashed it with the Pimoroni Pico uf2. It displays the senor readings, but doesn’t upload anything to the cloud. Very basic setup.
Hello alphanumeric, I flashed “pimoroni-picow-v1.21.0-micropython.uf2” to a second Pico HW and uploaded your code with Thonny. This worked without any problem. :-)
After that I flashed “pimoroni-picow-v1.21.0-micropython.uf2” to my Enviro indoor and the code worked again. :-)
At last I flashed “pimoroni-enviro-v1.21.0-micropython.uf2” to my Enviro indoor. I copied the exact same code to the device but no luck this time.
I’m getting the following error:
MPY: soft reboot
File "<stdin>", line 22, in <module>
RuntimeError: network connection failed
I guess it’s not the Picos fault, but it has something to do with the Enviro indoor.
Hello Curt, thank you for your advice. After the initial setup, I edited the config.py file via Thonny and inserted my Wifi password. Unfortunately, this is not working here. How did you edit the main.py to insert ssid and password there?
I actually modified config.py to get the wifi working:
# enviro config file
# you may edit this file by hand but if you enter provisioning mode
# then the file will be automatically overwritten with new details
provisioned = True
# enter a nickname for this board
nickname = 'dev'
# network access details
wifi_ssid = "My SSID"
wifi_password = "Way too Long password"
# how often to wake up and take a reading (in minutes)
reading_frequency = 15
#reading_frequency = 1
# how often to trigger a resync of the onboard RTC (in hours)
resync_frequency = 24
# where to upload to ("http", "mqtt", "adafruit_io", "influxdb")
destination = ''
# how often to upload data (number of cached readings)
upload_frequency = 5
# web hook settings
custom_http_url = ''
custom_http_username = ''
custom_http_password = ''
# mqtt broker settings
mqtt_broker_address = ''
mqtt_broker_username = ''
mqtt_broker_password = ''
# mqtt broker if using local SSL
mqtt_broker_ca_file = None
# adafruit ui settings
adafruit_io_username = ''
adafruit_io_key = ''
# influxdb settings
influxdb_org = ''
influxdb_url = ''
influxdb_token = ''
influxdb_bucket = ''
# grow specific settings
auto_water = False
moisture_target_a = 50
moisture_target_b = 50
moisture_target_c = 50
# compensate for usb power
usb_power_temperature_offset = 4.5
main.py was modified to a custom UDP interface. This is the display:
I flashed the “pimoroni-enviro-v1.21.0-micropython.uf2” to my Pico W and the code i posted above worked OK.
connected
ip = 192.168.2.29
Next step is to look up how that provisioning etc is done. I think I’ll do that on my Pico Enviro+. I have my current main.py saved to my PC so no big deal setting it back up when I’m done.
EDIT: All flashed and ready to provision, this PC doesn’t have any WIFI, lol.
Will have to go find a WIFI dongle, or boot up my Laptop or my Pi 400.
Will have to wait until after my morning walk though.
