There is a new board from Google called the Coral Dev Board Mini with the 40-pin GPIO headers.
The coral board has very powerful AI on board and I managed to get docker working on it also. It has 2GB RAM and is a major step up from the raspberry pi0 with onboard Coral TPU presented as a USB device
mendel@vexing-bunny:~/IOTstack$ lsusb
Bus 002 Device 003: ID 18d1:9302 Google Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
It would be lovely if someone got the enviro+ hat working on it instead of solely a measly raspberry pi0 or equivalent
Pimoroni don’t support anything outside Pi OS I’m afraid, and I don’t think too many people have Coral Dev Boards. You’d probably be better asking in Coral communities to see if there are any other Pi fans.
You could pick a piece and start there? Get the BME280 working, then the display etc.
I have the equivalent Breakout Garden setup, I just install each bits software separately.
0.96" SPI Color LCD (160x80) Breakout * ST7735S driver chip
BME280 Breakout - Temperature, Pressure, Humidity Sensor
LTR-559 Light & Proximity Sensor Breakout
When I’m done I can run the Eviro code, with some minor edits, on my setup.
