Enviro Phat Install Fails
Run curl -sS get.pimoroni.com/envirophat | bash
on a freshly installed Zero, get the following
Installing Enviro pHAT library for Python 2…
Downloading/unpacking envirophat
Cleaning up…
Exception:
File “/usr/lib/python2.7/dist-packages/pip/basecommand.py”, line 122, in main
status = self.run(options, args)
File “/usr/lib/python2.7/dist-packages/pip/commands/install.py”, line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File “/usr/lib/python2.7/dist-packages/pip/req.py”, line 1178, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 194, in find_requirement
page = self._get_page(main_index_url, req)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 568, in _get_page
session=self.session,
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 694, in get_page
req, link, “connection error: %s” % exc, url,
TypeError: str returned non-string (type Error)
Storing debug log for failure in /root/.pip/pip.log
Python 2 library install failed!
If problems persist, visit forums.pimoroni.com for support
Wow that’s a verbose error output for a simple failure. Darn pip is useless :D
The key words here are, I think, “req, link, “connection error: %s” % exc, url,”
Looks like you, or the Python package index, might be having some intermittent connection errors. Give it another go!
Will try again, actually tried a few times previously, all failed with the same, internet was working as far as idle same time browsing was OK. Other libraries get updated prior to this ok.
Worked after trying again, also got something similar for MicroDot phat, so it seems if you get a spurious message like this, just keep trying to do the install.
