Enviro Weather (Pico W Aboard) not connecting to wifi
Hi I have the Enviro Weather (Pico W Aboard) and i changed the location of uploads and now it will not connect to the wifi on battery power been ok for 3 weeks. i have done resets and changed the batteries its using 2 AAA battery pack. but if i connect to to usb and run the main script using thonny it works ok and connects to wifi is this a power issue or something else i have ordered the 3 AA battery pack to see if that works
just for information i have bought some new AAA batteries and the board is now connecting to WiFi and uploading the results.
the batteries i used earlier obviously had issues and not enough power when using the WiFi.
I did notice as in other post when going through the setup process the WiFi password gets truncated when checking on rerunning the setup or with viewing the config file in thonny
