I had a working enviroweather, its started reporting a temp of -40 degrees C. Also other readings seem weird :
{‘readings’: {‘rain_per_second’: 0, ‘pressure’: 741.09, ‘temperature’: -40.0, ‘humidity’: 37.44, ‘wind_direction’: 90, ‘luminance’: 24.6, ‘rain’: 0, ‘voltage’: 0.0, ‘wind_speed’: 0}, ‘nickname’: ‘green’, ‘model’: ‘weather’, ‘uid’: ‘e6614103e7356d22’, ‘timestamp’: ‘2023-08-07T17:14:32Z’}
Just in case there was some firmware corruption I reflashed with 0.9, this did not resolve the problem.
Has this been seen before or any ideas. It was stored in a PIMORONI weather enclosure and the problem happens on USB or battery power.
