Playing with an Enviro Weather. I have installed the 0.0.9 firmware.
I have noticed that the temp and humidity are very in-accurate when running on USB power. This appears to be due to the electronics heating up a bit when it is constantly powered. When allowed to cool to ambient (power off) and then turned on you can see the temp reading rising to 3-4 degrees higher that the room. For testing I have the sample time set to 1 minute. At the same time the humidity reading drops to show about 15% below the actual reading. I have several other sensors in the same place as the Enviro and they are generally withing 0.5 degree and +/- 3% RH. Using a thermal camera you can see that the sensor chips are getting some heat bleed from the RP2040. They really would benefit from being further from the RP2040 I think.
The project I am working on was going to power the Enviro board using USB power as I do not need to use batteries. Now I am going to use a 5V buck convertor to convert the power and connect it to the board via the plug which should fix the heating issue.
