Fan SHIM service failing
I am trying to set up the Fan SHIM service, but am running into a bit of an error (see below). Any help would be appreciated.
Some background… this is a Pi 4 with 2GB of RAM, running Volumio as the operating system, which is based on raspbian jesse. Initially, it only had python2.7, so I had to install python3 in order to run the Fan SHIM software. It does say that the debug log for the failure is in /root/.pip/pip.log, but that doesn’t seem to exist. The service does install, but fails to start.
Error follows…
Cleaning up…
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-3rkv40r8/psutil
Storing debug log for failure in /root/.pip/pip.log
Installing service to: /etc/systemd/system/pimoroni-fanshim.service
● pimoroni-fanshim.service - Fan Shim Service
Loaded: loaded (/etc/systemd/system/pimoroni-fanshim.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2020-08-08 16:12:44 EDT; 14ms ago
Process: 7940 ExecStart=/usr/bin/python3 /home/volumio/fanshim-python/examples/automatic.py --on-threshold 50 --off-threshold 45 --low-temp 45 --high-temp 50 --delay 2 --brightness 255 (code=exited, status=1/FAILURE)
Main PID: 7940 (code=exited, status=1/FAILURE)
Aug 08 16:12:44 rpi41w-vo systemd[1]: Unit pimoroni-fanshim.service entered failed state.
volumio@rpi41w-vo:~/fanshim-python/examples$ ls
automatic.py button.py install-service.sh led2.py led.py manual.py README.md toggle.py
volumio@rpi41w-vo:~/fanshim-python/examples$ sudo systemctl status pimoroni-fanshim.service
Active: failed (Result: start-limit) since Sat 2020-08-08 16:12:45 EDT; 2min 30s ago
Process: 7966 ExecStart=/usr/bin/python3 /home/volumio/fanshim-python/examples/automatic.py --on-threshold 50 --off-threshold 45 --low-temp 45 --high-temp 50 --delay 2 --brightness 255 (code=exited, status=1/FAILURE)
Main PID: 7966 (code=exited, status=1/FAILURE)
Aug 08 16:12:45 rpi41w-vo systemd[1]: Unit pimoroni-fanshim.service entered failed state.
Aug 08 16:12:45 rpi41w-vo systemd[1]: pimoroni-fanshim.service holdoff time over, scheduling restart.
Aug 08 16:12:45 rpi41w-vo systemd[1]: Stopping Fan Shim Service…
Aug 08 16:12:45 rpi41w-vo systemd[1]: Starting Fan Shim Service…
Aug 08 16:12:45 rpi41w-vo systemd[1]: pimoroni-fanshim.service start request repeated too quickly, refusing…tart.
Aug 08 16:12:45 rpi41w-vo systemd[1]: Failed to start Fan Shim Service.
Hint: Some lines were ellipsized, use -l to show in full.
Volumio as the operating system, which is based on raspbian Jesse. << That seems contradictory? A Pi 4 will not run on Jessie? It will only boot from Buster / PiOS.
You can control the Fan via a dtoverlay by the way. If you add the following to the config.txt file
dtoverlay=gpio-fan,gpiopin=18,temp=55000
the fan will turn on a 55c, and off again at 45c. You can change the 55000 to what ever turn on temp you want.
That will get you temperature control until you sort out your other issue.
What was the full command you entered to setup the service?
It goes something like this
cd fanshim-python
cd examples
sudo ./install-service.sh --on-threshold 55 --off-threshold 40 --delay 2
@alphanumeric Thanks for your reply.
The full command I entered was:
sudo ./install-service.sh --on-threshold 50 --off-threshold 45 --delay 2
This was copied directly from the instructions that came with the software.
BTW, you’re right about ‘jessie’ vs ‘buster’. That was a typo on my part. I was thinking ‘buster’, but I typed ‘jessie’. Thanks for the dtoverlay info. I’ll give that a shot. Are there similar options for controlling the LED and button?
The button can be used to boot up and shut down the Pi, its what i use it for.
If you shut down and leave the Pi Powered up, pressing the button will have it boot up.
The button grounds GPIO 3 when pressed and grounding GPIO 3 will boot up a powered Pi. That’s a function etched into the Pi’s silicon. It’s built in, no software or special config required.
The Pi can also be shutdown via GPIO 3. All you do is add the following line to the config.txt file.
dtoverlay=gpio-shutdown
If i2c is enabled it doesn’t work with GPIO 3 so I use the following with my fan shim just to play it safe. I switch it to GPIO 17.
dtoverlay=gpio-shutdown,gpio_pin=17,active_low=1,gpio_pull=up
The button actually grounds GPIO 3 and GPIO 17.
I have my fan shim modified so when the Pi is shutdown the fan is off. I cut a track on the board. It still runs when commanded on, it just won’t run all on its own by default anymore.
I don’t use the LED so I haven’t done anything with it so far. It can be used, you’d just have to do it with some python code, same deal with the button if you wanted to use it to control the fan. There is info here on the python commands to use.
