Hello,
I’m trying to turn a 16 MB pico lipo into a Chinese-English dictionary. My code works fine when there are only 1,000 entries in the dictionary, but when there are 10,000 entries, I get the following error when running make:
[ 97%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/lib/tinyusb/src/class/video/video_device.c.obj
[ 97%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/lib/tinyusb/src/portable/raspberrypi/pio_usb/dcd_pio_usb.c.obj
[ 97%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/lib/tinyusb/src/tusb.c.obj
[ 98%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/lib/tinyusb/src/common/tusb_fifo.c.obj
[ 98%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/src/rp2_common/pico_fix/rp2040_usb_device_enumeration/rp2040_usb_device_enumeration.c.obj
[ 98%] Building C object CMakeFiles/epd.dir/home/astra/pico/pico-sdk/src/rp2_common/hardware_spi/spi.c.obj
[100%] Linking CXX executable epd.elf
/usr/lib/gcc/arm-none-eabi/10.3.1/…/…/…/arm-none-eabi/bin/ld: epd.elf section.rodata' will not fit in regionFLASH’
/usr/lib/gcc/arm-none-eabi/10.3.1/…/…/…/arm-none-eabi/bin/ld: region `FLASH’ overflowed by 638420 bytes
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/epd.dir/build.make:1212: epd.elf] Error 1
make[1]: *** [CMakeFiles/Makefile2:1604: CMakeFiles/epd.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
Currently, the file containing font data for the Chinese characters is about 4.6 MB, and the file containing dictionary entries is about 800 kB, so it should be well within the space requirements.
I’m running cmake with the -D PICO_BOARD=“pimoroni_picolipo_16mb” option. Here’s what cmake spits out:
mycomputer@LAPTOP-61HUGN86:~/pyCode/dictForPico/build$ cmake -D PICO_BOARD=“pimoroni_picolipo_16mb” …
Using PICO_SDK_PATH from environment (‘/home/mycomputer/pico/pico-sdk’)
PICO_SDK_PATH is /home/mycomputer/pico/pico-sdk
Defaulting PICO_PLATFORM to rp2040 since not specified.
Defaulting PICO platform compiler to pico_arm_gcc since not specified.
– Defaulting build type to ‘Release’ since not specified.
PICO compiler is pico_arm_gcc
– The CXX compiler identification is GNU 10.3.1
– The C compiler identification is GNU 10.3.1
– The ASM compiler identification is GNU
– Found assembler: /usr/bin/arm-none-eabi-gcc
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/arm-none-eabi-g++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: /usr/bin/arm-none-eabi-gcc - skipped
– Detecting C compile features
– Detecting C compile features - done
Build type is Release
PICO target board is pimoroni_picolipo_16mb.
Using board configuration from /home/mycomputer/pico/pico-sdk/src/boards/include/boards/pimoroni_picolipo_16mb.h
– Found Python3: /usr/bin/python3.10 (found version “3.10.6”) found components: Interpreter
TinyUSB available at /home/mycomputer/pico/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040; enabling build support for USB.
BTstack available at /home/mycomputer/pico/pico-sdk/lib/btstack
cyw43-driver available at /home/mycomputer/pico/pico-sdk/lib/cyw43-driver
Pico W Bluetooth build support available.
lwIP available at /home/mycomputer/pico/pico-sdk/lib/lwip
mbedtls available at /home/mycomputer/pico/pico-sdk/lib/mbedtls
– Configuring done
– Generating done
– Build files have been written to: /home/mycomputer/pyCode/dictForPico/build
I know that pico-sdk/src/boards/include/boards/pimoroni_picolipo_16mb.h has
#ifndef PICO_FLASH_SIZE_BYTES
#define PICO_FLASH_SIZE_BYTES (16 * 1024 * 1024)
#endif
I changed the PICO_FLASH_SIZE_BYTES to be 166 MB instead of 16 just to see what would happen, and there was no effect - I still got the message that region `FLASH’ overflowed by 638420 bytes. How can I get my code to recognize that my pico actually does have 16MB of flash?
