Hello all - I could use a little help getting started with the Automation 2040W. I can’t get anything to run and it seems like it goes back to the pimoroni_i2c Library. I attached a screenshot showing the contents of my lib directory - any hints would be appreciated. Thanks!
What uf2 file was the PICO flashed with?
Your question led me to an answer! I had installed the latest file from Raspberry Pi instead of the one from Pimoroni. Switching to their uf2 got everything working. Thank you!
I had a feeling that might be the case. Now you can do some tinkering. =)
