Hi - I’ve been trying to do the dress for the weather project. https://projects.raspberrypi.org/en/projects/dress-for-the-weather/ I ran into an issue early on - the JSON list downloaded from the API was different - there is a new line after each value, while in the JSON list on github the values are all in the same line. (So when I’d do cities[0] it would return /n…) I replaced the JSON list I’d downloaded with the one on Github, which worked, and was able to convert the list to a dictionary. But I haven’t been able to go further: when I tried to test it in the shell (https://projects.raspberrypi.org/en/projects/dress-for-the-weather/7) it returned this error. Can anyone help me figure out what’s going on? Thank you!
>>> get_city_id()
File "<pyshell#7>", line 1, in <module>
get_city_id()
File "/home/dress-for-the-weather/weather.py", line 8, in get_city_id
data = [loads(line) for line in f]
File "/home/dress-for-the-weather/weather.py", line 8, in <listcomp>
File "/home/anaconda3/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/home/anaconda3/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/home/anaconda3/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 2 column 1 (char 1)
