How to do mirrored text?
Is there a function to mirror text, or mirror the contents of the display?
I want the display to read “nam OCIP” instead of “PICO man” so that when you put the display in front of a mirror you can read the text properly.
I am programming with Raspberry Pi Pico on the Pimoroni 0.96" display without breakout board, see my code below:
import utime
from pimoroni import Button # if using a button this function is necessary
from picographics import PicoGraphics # universal graphics library
from picographics import DISPLAY_LCD_160X80 # the class for my display model
from picographics import PEN_P4 # class for colour depth I want
display = PicoGraphics(display=DISPLAY_LCD_160X80, pen_type=PEN_P4, rotate=0) # create display object
X_max = 160 # define graphic bounds
Y_max = 80
display.set_backlight(1.0) # set backlight to max
display.set_font(“bitmap8”) # an easy to use and see font
RED = display.create_pen(255, 000, 000) # define specific colours, shows the quantity of (red, green, blue)
PURPLE = display.create_pen(255, 000, 255)
YELLOW = display.create_pen(255, 255, 000)
GREEN = display.create_pen(000, 255, 000)
CYAN = display.create_pen(000, 255, 255)
BLUE = display.create_pen(000, 000, 255)
def clear(): # a helpful function to clear the screen
display.set_pen(BLACK)
display.clear() # command from Picographics library
display.update() # update actually perfroms the function, buffer > screen output
clear()
display.set_pen(BLUE)
display.set_font(“bitmap6”)
display.text(“PICO Man”,15,30,scale=3)
display.update()
I had a quick look see here,
pimoroni-pico/micropython/modules/picographics at main · pimoroni/pimoroni-pico (github.com)
I didn’t see a flip function, which is what I think you need. Rotate isn’t going to do what you want.
You’re right I couldn’t see any flip function either.
As a work around I’ve thought about making my own font, like they did in this video: https://www.youtube.com/watch?v=BMlGyAYNdF8
Any ideas on a better/quicker/easier way of creating flipped text?
@Tonygo2 is likely the guy to ask?
I’ve been away for Christmas and this was an interesting diversion for a dull and dismal day.
I hope this is what you were looking for.
# Mirror text on a Display 2
# Tony Goodhew 27th Dec 2023
#import time
from picographics import PicoGraphics, DISPLAY_PICO_DISPLAY_2, PEN_P8
display = PicoGraphics(display=DISPLAY_PICO_DISPLAY_2, pen_type=PEN_P8)
# Standard ASCII 5x8 font
# https://gist.github.com/tdicola/229b3eeddc12d58fb0bc724a9062aa05
FONT_HEIGHT = 8
FONT_WIDTH = 5
FONT = bytes([
    0x00, 0x00, 0x00, 0x00, 0x00, # <space>
    0x3E, 0x5B, 0x4F, 0x5B, 0x3E,
    0x3E, 0x6B, 0x4F, 0x6B, 0x3E,
    0x1C, 0x3E, 0x7C, 0x3E, 0x1C,
    0x18, 0x3C, 0x7E, 0x3C, 0x18,
    0x1C, 0x57, 0x7D, 0x57, 0x1C,
    0x1C, 0x5E, 0x7F, 0x5E, 0x1C,
    0x00, 0x18, 0x3C, 0x18, 0x00,
    0xFF, 0xE7, 0xC3, 0xE7, 0xFF,
    0x00, 0x18, 0x24, 0x18, 0x00,
    0xFF, 0xE7, 0xDB, 0xE7, 0xFF,
    0x30, 0x48, 0x3A, 0x06, 0x0E,
    0x26, 0x29, 0x79, 0x29, 0x26,
    0x40, 0x7F, 0x05, 0x05, 0x07,
    0x40, 0x7F, 0x05, 0x25, 0x3F,
    0x5A, 0x3C, 0xE7, 0x3C, 0x5A,
    0x7F, 0x3E, 0x1C, 0x1C, 0x08,
    0x08, 0x1C, 0x1C, 0x3E, 0x7F,
    0x14, 0x22, 0x7F, 0x22, 0x14,
    0x5F, 0x5F, 0x00, 0x5F, 0x5F,
    0x06, 0x09, 0x7F, 0x01, 0x7F,
    0x00, 0x66, 0x89, 0x95, 0x6A,
    0x60, 0x60, 0x60, 0x60, 0x60,
    0x94, 0xA2, 0xFF, 0xA2, 0x94,
    0x08, 0x04, 0x7E, 0x04, 0x08, # UP
    0x10, 0x20, 0x7E, 0x20, 0x10, # Down
    0x08, 0x08, 0x2A, 0x1C, 0x08, # Right
    0x08, 0x1C, 0x2A, 0x08, 0x08, # Left
    0x1E, 0x10, 0x10, 0x10, 0x10,
    0x0C, 0x1E, 0x0C, 0x1E, 0x0C,
    0x30, 0x38, 0x3E, 0x38, 0x30,
    0x06, 0x0E, 0x3E, 0x0E, 0x06,
    0x00, 0x00, 0x5F, 0x00, 0x00,
    0x00, 0x07, 0x00, 0x07, 0x00,
    0x14, 0x7F, 0x14, 0x7F, 0x14,
    0x24, 0x2A, 0x7F, 0x2A, 0x12,
    0x23, 0x13, 0x08, 0x64, 0x62,
    0x36, 0x49, 0x56, 0x20, 0x50,
    0x00, 0x08, 0x07, 0x03, 0x00,
    0x00, 0x1C, 0x22, 0x41, 0x00,
    0x00, 0x41, 0x22, 0x1C, 0x00,
    0x2A, 0x1C, 0x7F, 0x1C, 0x2A,
    0x08, 0x08, 0x3E, 0x08, 0x08,
    0x00, 0x80, 0x70, 0x30, 0x00,
    0x08, 0x08, 0x08, 0x08, 0x08,
    0x00, 0x00, 0x60, 0x60, 0x00,
    0x20, 0x10, 0x08, 0x04, 0x02,
    0x3E, 0x51, 0x49, 0x45, 0x3E,
    0x00, 0x42, 0x7F, 0x40, 0x00,
    0x72, 0x49, 0x49, 0x49, 0x46,
    0x21, 0x41, 0x49, 0x4D, 0x33,
    0x18, 0x14, 0x12, 0x7F, 0x10,
    0x27, 0x45, 0x45, 0x45, 0x39,
    0x3C, 0x4A, 0x49, 0x49, 0x31,
    0x41, 0x21, 0x11, 0x09, 0x07,
    0x36, 0x49, 0x49, 0x49, 0x36,
    0x46, 0x49, 0x49, 0x29, 0x1E,
    0x00, 0x00, 0x14, 0x00, 0x00,
    0x00, 0x40, 0x34, 0x00, 0x00,
    0x00, 0x08, 0x14, 0x22, 0x41,
    0x14, 0x14, 0x14, 0x14, 0x14,
    0x00, 0x41, 0x22, 0x14, 0x08,
    0x02, 0x01, 0x59, 0x09, 0x06,
    0x3E, 0x41, 0x5D, 0x59, 0x4E,
    0x7C, 0x12, 0x11, 0x12, 0x7C, # A
    0x7F, 0x49, 0x49, 0x49, 0x36,
    0x3E, 0x41, 0x41, 0x41, 0x22,
    0x7F, 0x41, 0x41, 0x41, 0x3E,
    0x7F, 0x49, 0x49, 0x49, 0x41,
    0x7F, 0x09, 0x09, 0x09, 0x01,
    0x3E, 0x41, 0x41, 0x51, 0x73,
    0x7F, 0x08, 0x08, 0x08, 0x7F,
    0x00, 0x41, 0x7F, 0x41, 0x00,
    0x20, 0x40, 0x41, 0x3F, 0x01,
    0x7F, 0x08, 0x14, 0x22, 0x41,
    0x7F, 0x40, 0x40, 0x40, 0x40,
    0x7F, 0x02, 0x1C, 0x02, 0x7F,
    0x7F, 0x04, 0x08, 0x10, 0x7F,
    0x3E, 0x41, 0x41, 0x41, 0x3E,
    0x7F, 0x09, 0x09, 0x09, 0x06,
    0x3E, 0x41, 0x51, 0x21, 0x5E,
    0x7F, 0x09, 0x19, 0x29, 0x46,
    0x26, 0x49, 0x49, 0x49, 0x32,
    0x03, 0x01, 0x7F, 0x01, 0x03,
    0x3F, 0x40, 0x40, 0x40, 0x3F,
    0x1F, 0x20, 0x40, 0x20, 0x1F,
    0x3F, 0x40, 0x38, 0x40, 0x3F,
    0x63, 0x14, 0x08, 0x14, 0x63,
    0x03, 0x04, 0x78, 0x04, 0x03,
    0x61, 0x59, 0x49, 0x4D, 0x43,
    0x00, 0x7F, 0x41, 0x41, 0x41,
    0x02, 0x04, 0x08, 0x10, 0x20,
    0x00, 0x41, 0x41, 0x41, 0x7F,
    0x04, 0x02, 0x01, 0x02, 0x04,
    0x40, 0x40, 0x40, 0x40, 0x40,
    0x00, 0x03, 0x07, 0x08, 0x00,
    0x20, 0x54, 0x54, 0x78, 0x40,
    0x7F, 0x28, 0x44, 0x44, 0x38,
    0x38, 0x44, 0x44, 0x44, 0x28,
    0x38, 0x44, 0x44, 0x28, 0x7F,
    0x38, 0x54, 0x54, 0x54, 0x18,
    0x00, 0x08, 0x7E, 0x09, 0x02,
    0x18, 0xA4, 0xA4, 0x9C, 0x78,
    0x7F, 0x08, 0x04, 0x04, 0x78,
    0x00, 0x44, 0x7D, 0x40, 0x00,
    0x20, 0x40, 0x40, 0x3D, 0x00,
    0x7F, 0x10, 0x28, 0x44, 0x00,
    0x00, 0x41, 0x7F, 0x40, 0x00,
    0x7C, 0x04, 0x78, 0x04, 0x78,
    0x7C, 0x08, 0x04, 0x04, 0x78,
    0x38, 0x44, 0x44, 0x44, 0x38,
    0xFC, 0x18, 0x24, 0x24, 0x18,
    0x18, 0x24, 0x24, 0x18, 0xFC,
    0x7C, 0x08, 0x04, 0x04, 0x08,
    0x48, 0x54, 0x54, 0x54, 0x24,
    0x04, 0x04, 0x3F, 0x44, 0x24,
    0x3C, 0x40, 0x40, 0x20, 0x7C,
    0x1C, 0x20, 0x40, 0x20, 0x1C,
    0x3C, 0x40, 0x30, 0x40, 0x3C,
    0x44, 0x28, 0x10, 0x28, 0x44,
    0x4C, 0x90, 0x90, 0x90, 0x7C,
    0x44, 0x64, 0x54, 0x4C, 0x44,
    0x00, 0x08, 0x36, 0x41, 0x00,
    0x00, 0x00, 0x77, 0x00, 0x00,
    0x00, 0x41, 0x36, 0x08, 0x00,
    0x02, 0x01, 0x02, 0x04, 0x02,
    0x3C, 0x26, 0x23, 0x26, 0x3C,
    0x1E, 0xA1, 0xA1, 0x61, 0x12, # Extension starts here
    0x3A, 0x40, 0x40, 0x20, 0x7A,
    0x38, 0x54, 0x54, 0x55, 0x59,
    0x21, 0x55, 0x55, 0x79, 0x41,
    0x22, 0x54, 0x54, 0x78, 0x42, # a-umlaut
    0x21, 0x55, 0x54, 0x78, 0x40,
    0x20, 0x54, 0x55, 0x79, 0x40,
    0x0C, 0x1E, 0x52, 0x72, 0x12,
    0x39, 0x55, 0x55, 0x55, 0x59,
    0x39, 0x54, 0x54, 0x54, 0x59,
    0x39, 0x55, 0x54, 0x54, 0x58,
    0x00, 0x00, 0x45, 0x7C, 0x41,
    0x00, 0x02, 0x45, 0x7D, 0x42,
    0x00, 0x01, 0x45, 0x7C, 0x40,
    0x7D, 0x12, 0x11, 0x12, 0x7D, # A-umlaut
    0xF0, 0x28, 0x25, 0x28, 0xF0,
    0x7C, 0x54, 0x55, 0x45, 0x00,
    0x20, 0x54, 0x54, 0x7C, 0x54,
    0x7C, 0x0A, 0x09, 0x7F, 0x49,
    0x32, 0x49, 0x49, 0x49, 0x32,
    0x3A, 0x44, 0x44, 0x44, 0x3A, # o-umlaut
    0x32, 0x4A, 0x48, 0x48, 0x30,
    0x3A, 0x41, 0x41, 0x21, 0x7A,
    0x3A, 0x42, 0x40, 0x20, 0x78,
    0x00, 0x9D, 0xA0, 0xA0, 0x7D,
    0x3D, 0x42, 0x42, 0x42, 0x3D, # O-umlaut
    0x3D, 0x40, 0x40, 0x40, 0x3D,
    0x3C, 0x24, 0xFF, 0x24, 0x24,
    0x48, 0x7E, 0x49, 0x43, 0x66,
    0x2B, 0x2F, 0xFC, 0x2F, 0x2B,
    0xFF, 0x09, 0x29, 0xF6, 0x20,
    0xC0, 0x88, 0x7E, 0x09, 0x03,
    0x20, 0x54, 0x54, 0x79, 0x41,
    0x00, 0x00, 0x44, 0x7D, 0x41,
    0x30, 0x48, 0x48, 0x4A, 0x32,
    0x38, 0x40, 0x40, 0x22, 0x7A,
    0x00, 0x7A, 0x0A, 0x0A, 0x72,
    0x7D, 0x0D, 0x19, 0x31, 0x7D,
    0x26, 0x29, 0x29, 0x2F, 0x28,
    0x26, 0x29, 0x29, 0x29, 0x26,
    0x30, 0x48, 0x4D, 0x40, 0x20,
    0x38, 0x08, 0x08, 0x08, 0x08,
    0x08, 0x08, 0x08, 0x08, 0x38,
    0x2F, 0x10, 0xC8, 0xAC, 0xBA,
    0x2F, 0x10, 0x28, 0x34, 0xFA,
    0x00, 0x00, 0x7B, 0x00, 0x00,
    0x08, 0x14, 0x2A, 0x14, 0x22,
    0x22, 0x14, 0x2A, 0x14, 0x08,
    0x55, 0x00, 0x55, 0x00, 0x55, # 176 (25% block) missing in old code
    0xAA, 0x55, 0xAA, 0x55, 0xAA, # 50% block
    0xFF, 0x55, 0xFF, 0x55, 0xFF, # 75% block
    0x00, 0x00, 0x00, 0xFF, 0x00,
    0x10, 0x10, 0x10, 0xFF, 0x00,
    0x14, 0x14, 0x14, 0xFF, 0x00,
    0x10, 0x10, 0xFF, 0x00, 0xFF,
    0x10, 0x10, 0xF0, 0x10, 0xF0,
    0x14, 0x14, 0x14, 0xFC, 0x00,
    0x14, 0x14, 0xF7, 0x00, 0xFF,
    0x00, 0x00, 0xFF, 0x00, 0xFF,
    0x14, 0x14, 0xF4, 0x04, 0xFC,
    0x14, 0x14, 0x17, 0x10, 0x1F,
    0x10, 0x10, 0x1F, 0x10, 0x1F,
    0x14, 0x14, 0x14, 0x1F, 0x00,
    0x10, 0x10, 0x10, 0xF0, 0x00,
    0x00, 0x00, 0x00, 0x1F, 0x10,
    0x10, 0x10, 0x10, 0x1F, 0x10,
    0x10, 0x10, 0x10, 0xF0, 0x10,
    0x00, 0x00, 0x00, 0xFF, 0x10,
    0x10, 0x10, 0x10, 0x10, 0x10,
    0x10, 0x10, 0x10, 0xFF, 0x10,
    0x00, 0x00, 0x00, 0xFF, 0x14,
    0x00, 0x00, 0x1F, 0x10, 0x17,
    0x00, 0x00, 0xFC, 0x04, 0xF4,
    0x14, 0x14, 0x17, 0x10, 0x17,
    0x14, 0x14, 0xF4, 0x04, 0xF4,
    0x00, 0x00, 0xFF, 0x00, 0xF7,
    0x14, 0x14, 0xF7, 0x00, 0xF7,
    0x14, 0x14, 0x14, 0x17, 0x14,
    0x14, 0x14, 0x14, 0xF4, 0x14,
    0x00, 0x00, 0x1F, 0x10, 0x1F,
    0x00, 0x00, 0x00, 0x1F, 0x14,
    0x00, 0x00, 0x00, 0xFC, 0x14,
    0x00, 0x00, 0xF0, 0x10, 0xF0,
    0x10, 0x10, 0xFF, 0x10, 0xFF,
    0x14, 0x14, 0x14, 0xFF, 0x14,
    0x10, 0x10, 0x10, 0x1F, 0x00,
    0x00, 0x00, 0x00, 0xF0, 0x10,
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
    0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
    0xFF, 0xFF, 0xFF, 0x00, 0x00,
    0x00, 0x00, 0x00, 0xFF, 0xFF,
    0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
    0x38, 0x44, 0x44, 0x38, 0x44, # alpha - Greek characters start here  at 224
    0xFC, 0x4A, 0x4A, 0x4A, 0x34, # sharp-s or beta
    0x7E, 0x02, 0x02, 0x06, 0x06,
    0x02, 0x7E, 0x02, 0x7E, 0x02, # pi
    0x63, 0x55, 0x49, 0x41, 0x63,
    0x38, 0x44, 0x44, 0x3C, 0x04,
    0x40, 0x7E, 0x20, 0x1E, 0x20, # mu
    0x06, 0x02, 0x7E, 0x02, 0x02,
    0x99, 0xA5, 0xE7, 0xA5, 0x99,
    0x1C, 0x2A, 0x49, 0x2A, 0x1C,
    0x4C, 0x72, 0x01, 0x72, 0x4C, # omega
    0x30, 0x4A, 0x4D, 0x4D, 0x30,
    0x30, 0x48, 0x78, 0x48, 0x30,
    0xBC, 0x62, 0x5A, 0x46, 0x3D,
    0x3E, 0x49, 0x49, 0x49, 0x00,
    0x7E, 0x01, 0x01, 0x01, 0x7E, # End of Greek chars
    0x2A, 0x2A, 0x2A, 0x2A, 0x2A, # equivalent to 240
    0x44, 0x44, 0x5F, 0x44, 0x44, # + or -
    0x40, 0x51, 0x4A, 0x44, 0x40, # >=
    0x40, 0x44, 0x4A, 0x51, 0x40, # <=
    0x00, 0x00, 0xFF, 0x01, 0x03, # top of integral
    0xE0, 0x80, 0xFF, 0x00, 0x00, # bottom of integral
    0x08, 0x08, 0x6B, 0x6B, 0x08,
    0x36, 0x12, 0x36, 0x24, 0x36, # approximately
    0x06, 0x0F, 0x09, 0x0F, 0x06, # Degree
    0x00, 0x00, 0x18, 0x18, 0x00,
    0x00, 0x00, 0x10, 0x10, 0x00,
    0x30, 0x40, 0xFF, 0x01, 0x01, # sq root
    0x00, 0x1F, 0x01, 0x01, 0x1E, # n superscript
    0x00, 0x19, 0x1D, 0x17, 0x12, # squared (^2)
    0x00, 0x3C, 0x3C, 0x3C, 0x3C,
    0x00, 0x00, 0x00, 0x00, 0x00  # 255 also a <space>
def character(asc,xt,yt,sz):  # Single character sz is size: 1 or 2
    code = asc * 5    # 5 bytes per character
    for ii in range(5):
        line = FONT[code + ii]
        for yy in range(8):
            if (line >> yy) & 0x1:
                display.pixel(ii*sz+xt,yy*sz+yt)
                if sz > 1:
                    display.pixel(ii*sz+xt+1,yy*sz+yt)
                    display.pixel(ii*sz+xt,yy*sz+yt+1)
                    display.pixel(ii*sz+xt+1,yy*sz+yt+1)
                if sz == 3:
                    display.pixel(ii*sz+xt,  yy*sz+yt+2)
                    display.pixel(ii*sz+xt+1,yy*sz+yt+2)
                    display.pixel(ii*sz+xt+2,yy*sz+yt+2)
                    display.pixel(ii*sz+xt+2,yy*sz+yt)
                    display.pixel(ii*sz+xt+2,yy*sz+yt+1)
def character_m(asc,xt,yt,sz):  # Single character sz is size: 1 or 2
    for ii in range(5):
        line = FONT[code + 4 - ii]
        for yy in range(8):
                if sz > 1:
                if sz == 3:
def prnt_st_m(asci,xx,yy,sz):  # Text string
    t = asci    # Revesre letter order
    l = len(t)
    asci = ""
    for i in range(l):
        asci = asci + t[l-i-1]
    if sz == 1: move = 6
    if sz == 2: move = 11
    if sz == 3: move = 17
    for letter in(asci):
        asci = ord(letter)
        character_m(asci,xx,yy,sz)
        xx = xx + move
def prnt_st(asci,xx,yy,sz):  # Text string
        asci = ord(letter)
        character(asci,xx,yy,sz)
        xx = xx + move
def cntr_st(s,y,sz): # Centres text on line y
    if sz == 1: w = 6
    if sz == 2: w = 11
    if sz == 3: w = 17
    gap = int((width - len(s) * w)/2)
    prnt_st(s,gap,y,sz)
# =========== End of font support routines ===========
BLACK = display.create_pen(0, 0, 0)         #0
WHITE = display.create_pen(255,255,255)     #255
YELLOW = display.create_pen(200,200,0)      #216
GREEN = display.create_pen(0,255,0)         #28
BLUE = display.create_pen(0,0,255)          #3
RED = display.create_pen(255,0,0)           #224
display.clear()
display.set_pen(RED)
t= "Tony"
prnt_st(t,20,20,3)
prnt_st_m(t,160,20,3)
display.update()
display.set_pen(GREEN)
t= "Mirror"
prnt_st(t,20,50,3)
prnt_st_m(t,160,50,3)
display.set_pen(YELLOW)
prnt_st("Mirrored Text",20,100,3)
prnt_st_m("abcdefghjklmnopqrstuvwxyz",20,200,2)
display.update()
I’ve used a 5x8 font but it would be easy convert to 8x8. I’ve left the centred mirrored for you to try.
I wish you all successful coding in the New Year - Have a great time.
Thanks Tony, I had a feeling you would be the one to ask / know how to do it. =)
Thanks so much @Tonygo2 and @alphanumeric for the help. I shall work on converting the code now :)
