Hyperpixel 2.1 heavy noise on Zero 2W, Bookworm 6.12.75
Hello,
Just bought Hyperpixel 2.1 and trying to make it work with Zero 2W under rpios bookworm. 11.2025 Bookworm Image stock kernel (6.12.47) does not work at all. Latest 6.12.75 works but lot of green/pink noise on video/camera play. I previously encountered a similar problem when using an HDMI display, which turned out to be caused by a weak HDMI signal. That issue was resolved by increasing the HDMI boost via configuration config_hdmi_boost. But in this case it does not work.
