Y axis still not flipped correctly… how does this matrix even work?!
I think 0 -1 1 1 0 0 0 0 1 should work for you.
Which should be the same as removing display_rotate=2 from your /boot/config.txt and using hyperpixel4-rotate left in theory.
If this works you need to save it into /etc/udev/rules.d/98-hyperpixel4-calibration.rules
I never had display_rotate in my config.txt, would that be impacting anything?
Edit: y axis still isn’t flipping???
Just to confirm, you said 0 1 0 1 0 0 0 0 1 gave you a correct Y axis but an incorrect X axis?
On my setup switching from 0 1 0 1 0 0 0 0 1 to 0 -1 1 1 0 0 0 0 1 flips only the X axis.
Using hyperpixel4-rotate right
0 1 0 1 0 0 0 0 1 : y axis flipped x axis correct
0 -1 1 1 0 0 0 0 1 : y axis flipped x axis correct
Judging by the fact both of those transformations produce the same result, I’m guessing they are having no effect whatsoever which might explain a thing or two.
What do you see if you run:
xinput list-props “pointer:Goodix Capacitive TouchScreen”
It might be that you need to change libinput Calibration Matrix instead, perhaps.
Solved!
After gadgetoid and I had a muck around with different matrix setups, this is the one needed when rotating the screen right:
-1 0 1 0 1 0
Input this into /usr/bin/hyperpixel4-rotate, replace the $ORIENTATION == right if statement with
if [ "$ORIENTATION" == "right" ]; then
set_display $ORIENTATION
set_matrix -1 0 1 0 1 0
exit 0
fi
Hi there!
You could be my saver… :)
Could you please send me the matrix setup when rotating the screen left?
Thanks a lot!
What specifically do you want to know? I believe my previous comment where I detailed the solution to this problem was sufficient. I will copy it:
Input this into /usr/bin/hyperpixel4-rotate , replace the $ORIENTATION == right if statement with
exit 0
fi
Yes… Your solution works very well if I use the rotation to the right (with the USB-C power port up).
I need to use my raspberry with the power port down, so I have to run hyperpixel4-rotate left command in terminal. In this situation, my touchscreen doesn’t act as it should (if I move to the right the cursor moves to the left, and if I move up the cursor moves down)…
That is why I will need to modify that file in this section:
if [ "$ORIENTATION" == "left" ]; then
exit 0
fi
Could you please help me with the good matrix values?
You’ll need to look up a matrix transposing calculator online and do trial and error until you find the one which suits the current format of your screen. I don’t have your setup so I can’t really test myself.
Try ncase.me/matrix/
OK… So, if anybody have problems with hyperpixel4 display on Pi4 this is how need to be done:
A. Landscape / USB-C charging port down:
1. modify /usr/bin/hyperpixel4-rotate
set_matrix 1 0 0 0 -1 1
exit 0
fi
2. run in terminal: hyperpixel4-rotate left
B. Landscape / USB-C charging port up:
exit 0
fi
2. run in terminal: hyperpixel4-rotate right
