After installing the square Hyperpixel, I cannot seem to get analog audio to be enabled. I get an icon on the volume indicator that audio is disabled, and alsamixer cannot start from the command line. Is it possible to run the Hyperpixel and analog audio at the same time?
Hyperpixel should allow normal audio. Check config.txt for audio settings being disabled.
