Possible to combine Audio Amp SHIM with HyperPixel Round?
Hi there. I understand the HyperPixel Round “uses basically all of the GPIO pins o communicate with the Pi (including the standard I2C pins) so it’s not generally possible to use it with other HATs and devices that connect via the GPIO…” ; does that imply I cannot sandwich an Audio Amp SHIM in-between, or is that a possibility by chance?
Not going to work, the Hyperpixel is using the pins needed for the DAC to work.
