Hyperpixel Touch offset when rotated
Hi
My Hyperpixel 4.0 Rectangle is working well in its default portrait orientation.
When I change rotation to “Left” as documented, via the Screen Configuration in the GUI, the touch screen is no longer accurate - like others have said, by 50 pixels or so.
I’m running the latest Bookworm, fully up to date, and my config.txt is below.
I saw a bunch of older similar posts, but they seem to be specific to the Bullseye release. Couldn’t find anything specific to the built-in driver setup.
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[all]
enable_uart=1
dtoverlay=vc4-kms-dpi-hyperpixel4
