Hyperpixel & volumio
Hello,
Do you know/has anyone managed to get hyperpixel to work alongside volumio?
BW,
Did you ever get this working?
I just checked and Volumio is a Linux distribution in the end, I didn’t do further research, but you could always try to install it on a micro SD, boot up the system and see if you can open the terminal and follow the instructions from https://github.com/pimoroni/hyperpixel4
and see if it works, should be less than an hour work intotal :)
