I am currently scrolling my weather info on a Sense Hat 8x8 RGB LED matrix. I want to switch to 16x16 RGB and use a BME680 for the readings. The BME680 part is already done, all I’m using on the Sense hat now is the LED matrix. My text changes color based on the values, blue text for temp if it 0c or lower for example. The message endlessly repeats day, date, time, temp, humidity, pressure, UV index.
Seeing as there is no Scroll Hat HD I went with the Unicron Hat HD. I did a forum search and saw one thread on displaying a variable on the Unicorn Hat HD. To be honest I was lost as to what was done and why. So I decided to start my own new thread. My current python code is as follows. Be warned, there is a lot going on.
import os
import time, datetime
import bme680
import SI1145.SI1145 as SI1145
import ledshim
import RPi.GPIO as GPIO
from sense_hat import SenseHat, ACTION_PRESSED, ACTION_HELD, ACTION_RELEASED
ledshim.set_clear_on_exit()
sense = SenseHat()
sense.set_rotation(180)
sense.set_imu_config(False, False, False)
sense.low_light = False
uvs = SI1145.SI1145()
sensor = bme680.BME680()
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.DISABLE_GAS_MEAS)
#sensor.set_gas_heater_temperature(320)
#sensor.set_gas_heater_duration(150)
#sensor.select_gas_heater_profile(0)
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(5, GPIO.IN, pull_up_down = GPIO.PUD_OFF)
s=(0.1) # scroll speed
w=(0) # color all white toggle
o=(140) # orange white toggle value
x=(2) # shutdown variable
A=(1) # Auto mode
def set_multiple_pixels(indexes, r, g, b):
for index in indexes:
ledshim.set_pixel(index, r, g, b)
def Shutdown(channel):
global x
x = (0)
def readvis():
vis = uvs.readVisible()
vis = (round(vis))
global w
global o
global A
if vis < 270 and A == (1):
sense.low_light = True
ledshim.set_brightness(0.4)
ledshim.show()
w = (0)
o = (140)
elif vis >= 270 and vis < 650 and A == (1):
ledshim.set_brightness(1.0)
ledshim.show()
w = (0)
o = (140)
elif vis >= 650 and A == (1):
ledshim.show()
w = (255)
o = (255)
def ledtemp():
if sensor.get_sensor_data():
t = (sensor.data.temperature)
t = (round(t))
if t > 28: # Realy Hot
set_multiple_pixels(range(0,27), 255, 0, 0) # Red
set_multiple_pixels(range(27,28), 255,140, 0) # Orange
M = (t - 56) * (-1)
ledshim.set_pixel(M, 255, 255, 255)
# R R R R R R R R R R R R R R R R R R R R R R R R R R R O
elif t > 0 and t <= 28: # Main
set_multiple_pixels(range(0,3), 255, 140, 0) # Orange
set_multiple_pixels(range(3,16), 0, 255, 0) # Green
set_multiple_pixels(range(16,28), 255, 255, 0) # Yellow
M = (28 - t)
# O O O G G G G G G G G G G G G G Y Y Y Y Y Y Y Y Y Y Y Y
elif t <= 0 and t >= -27:
ledshim.set_all(0, 0, 255) #Blue
M = (t * (-1))
# B B B B B B B B B B B B B B B B B B B B B B B B B B B B
elif t > -27:
set_multiple_pixels(range(0,3), 255, 255, 255) #Blue
set_multiple_pixels(range(3,28), 0, 255, 255) #Aqua
M = (56 + t)
# B B B A A A A A A A A A A A A A A A A A A A A A A A A A
ledshim.show()
# is really stick down
def pushed_up(event):
global A
if event.action == ACTION_PRESSED:
ledshim.show()
A = (0)
# is really stick up
def pushed_down(event):
global A
ledshim.show()
A = (0)
#is really stick right
def pushed_left(event):
global w
global o
global A
w = (255)
o = (255)
A = (0)
# is really stick left
def pushed_right(event):
global w
global o
global A
w = (0)
o = (140)
A = (0)
def pushed_middle(event):
global A
A = (1)
sense.stick.direction_up = pushed_up
sense.stick.direction_down = pushed_down
sense.stick.direction_left = pushed_left
sense.stick.direction_right = pushed_right
sense.stick.direction_middle = pushed_middle
GPIO.add_event_detect(5, GPIO.FALLING, callback = Shutdown, bouncetime = 2000)
readvis()
ledtemp()
dateString = "%A %B %-d %-I:%M:%p"
msg = "It is %s" % (datetime.datetime.now().strftime(dateString))
sense.show_message(msg, scroll_speed=s, text_colour=(w, 255, 255))
t = (round(t))
if t <= 0:
tc = [w, w, 255] # Blue
elif t > 0 and t < 13:
tc = [255, 255, w] # Yellow
elif t >= 13 and t <= 25:
tc = [w, 255, w] # Green
elif t > 25 and t < 30:
tc = [255, o, w] # Orange
elif t >= 30:
tc = [255, w, w] # Red
msg = "and %sc" % (t)
sense.show_message(msg, scroll_speed=s, text_colour=tc)
readvis()
ledtemp()
h = (sensor.data.humidity)
h = (round(h))
if h < 0:
h = 0
if h > 100:
h = 100
if h < 30:
hc = [255, w, w] # Red
elif h >= 30 and h <= 60:
hc = [w, 255, w] # Green
elif h > 60 and h < 80:
hc = [255, 255, w] # Yellow
elif h >= 80:
msg = "with %s%% Humidity" % (h)
sense.show_message(msg, scroll_speed=s, text_colour=hc)
readvis()
ledtemp()
p = (sensor.data.pressure)
p = round(p)
if p > 0 and p < 982:
pc = [255, w, w] # Red
msg = "- Barometer is Very Low @ %smb - Storm Watch" % (p)
sense.show_message(msg, scroll_speed=s, text_colour=pc)
elif p >= 982 and p < 1004:
pc = [255, 255, w] # Yellow
msg = "- Barometer is Low @ %smb - Possible Percipitation" % (p)
elif p >= 1004 and p < 1026:
pc = [w, 255, w] # Green
msg = "- Barometer is Mid Range @ %smb" % (p)
elif p >= 1026 and p < 1048:
pc = [w, w, 255] # Blue
msg = "- Barometer is High @ %smb" % (p)
elif p >= 1048:
msg = "- Barometer is Very High @ %smb - Expect Dry Conditions" % (p)
readvis()
ledtemp()
uv = uvs.readUV()
u = uv/100
u = (round(u))
if u > 0 and u < 3:
msg = "- UV Index is Low @ %s" % (u)
sense.show_message(msg, scroll_speed=s, text_colour=(w, 255, w)) # Green
elif u >= 3 and u < 6:
msg = "- UV Index is Moderate @ %s" % (u)
sense.show_message(msg, scroll_speed=s, text_colour=(255, 255, w)) # Yellow
elif u >= 6 and u < 8:
msg = "- UV Index is High @ %s" % (u)
sense.show_message(msg, scroll_speed=s, text_colour=(255, o, w)) # Orange
elif u >= 8 and u < 11:
msg = "- UV Index is Very High @ %s" % (u)
sense.show_message(msg, scroll_speed=s, text_colour=(255, w ,w)) # Red
elif u >= 11:
msg = "- UV Index is Extreme @ %s" % (u)
sense.show_message(msg, scroll_speed=s, text_colour=(255, w, 255)) # Violet
#vis = uvs.readVisible()
#vis = (round(vis))
#msg = "and the VIS is %s" % (vis)
#sense.show_message(msg, scroll_speed=s, text_colour=(255, w, 255))
if x == 0:
sense.clear()
ledshim.clear()
ledshim.show()
time.sleep(30)
elif x == 1:
sense.clear()
ledshim.clear()
ledshim.show()
raise SystemExit
time.sleep(30)
# Last edited on Sep 15th 2018, fixed typo
# curl https://get.pimoroni.com/bme680 | bash
# curl https://get.pimoroni.com/ledshim | bash
# run sudo crontab -e
# add
# @reboot python3 /home/pi/BMELED.py &
All I want to do initially is display say the temperature, and get it to change color based on its value. If I can do that I should be able to just repeat it for the others.
Even just showing the day date time will be a step in the right direction. The example file just seemed overly complex for what I ant to do. I’m no python expert but I don’t consider myself a noob either. any help will be muchly appreciated.
