Inky Frame RTC Wakeup Problem
I’ve a new Inky Frame 5.7 and am trying to essentially replicate the photo gallery example with some tweaks.
The idea is that the main.py chooses a random photo from the SD card, displays it, then goes to sleep for a while.
This all works fine except that the RTC wakeup never seems to happen. Manually restarting the Pico or pressing one of the front buttons to generate a hardware interrupt gets it to run, but left to its own devices the system won’t wake.
Relevant code from main.py:
import inky_helper
activity_led = Pin(6, Pin.OUT)
activity_led.on()
#do stuff
activity_led.off()
inky_helper.sleep(5)
What am I missing?
Turns out that even whilst using inky_helper for sleep stuff, I still needed to hold VSYS while running to stay awake.
