Inky Impression 13 not working with PiSugar3
Lately I’ve been playing with a Inky Impression 7 and 13 inch. Since I want my project to be portable, I’ve bought a Pisugar 3 since it doesn’t use any GPIO pins and I am still able to mount the Pi (Zero 2w) on the board.
I am able to run the Pi + Sugar with no problems on the 7 inch screen, but when I use it on the 13 inch screen, most of the time I am not able to update the screen (using the examples).
A strange thing I came across is when I disconnect the battery on the PiSugar and reconnect it (I’ve soldered a connector on it, normally the battery is hard-wired) the PiSugar (and therefor also the Pi) auto-boots. In this situation the examples are running and everything seems to work fine.
Here again, when I do a soft shutdown and restart everything manually, the screen doesn’'t update no more. The examples for led and buttons do work in every situation.
When I completely remove the PiSugar and directly power the Pi, everything works fine.
Can someone tell me why the 13” screen doesnt work with the Pi + Sugar config, but the 7” does?
Very interesting. I was considering buying the pisugar 3 for this exact setup. I wanted to use the witty pi 4 mini but that and the 13.3” screen both use pin 17 so I don’t know if that’ll be an issue(I’m a complete noob with all of this). It seems like the pisugar would solve all my issues, but it has mixed reviews with its connections… but if it doesn’t even work on the larger screen than it looks like I’m back to square 1 again.
I also bought the witty pi because I didn’t check GPIO usage. One other problem with the witty is that is using the gpio pins, so to connect it to the Inky impression you’ll need header extenders.
I’ve ordered a new pisugar + and zero w to make sure it is not a hardware issue.
Hey, did you have any luck with the new hardware?
I’m working on a similar project, but monitoring the forum I can see issues with both Witty Pi and Pi Sugar.
Can you try with the fix from Inky Impression 13.3" + Witty Pi + Raspberry Pi Zero W2 not working - #14 by exlex
I thought this was the solution for my problem, but after more testing I still have the same issues.
Could you please explain what a “soft shutdown” is? And what is a manual restart?
A sudo reboot. When I disconnect (and reconnect) the battery it automaticly powers on the PiSugar + Pi. Then the image changing does work.
On a sudo reboot, it doesn’t
Thanks. I suspect that a reboot (or shutdown) does not do a POR (power on reset) on the display. To investigate, run sudo shutdown and then measure the voltages on the 3V3 and 5V of the display. The GPIO connector provides these pins.
When running without the Sugar, have you tried running an example program multiple times without a reboot inbetween? I am asking this since the driver should put the display into power-off mode after a refresh. It should not need a POR. But currently this seems to be the only difference there is between unplugging the battery and a mere reboot.
I’'ll try and measure those 3v3 and 5v points later.
When you mean run the stripes.py example, then a hello_world.py example? Then Yes. When running without the Sugar I can indeed run the program multiple times (without rebooting) with no problem. Also after a sudo reboot, everything keeps working flawless.
However, when I turn the PiSugar (and therefor also the Pi) of using the off-button on the Sugar, and then turn it on, the examples also don’t work.
Everything really only works when I had a short battery disconnect, or run the system without the PiSugar.
This keeps me scratching my head. So we know by now that POR makes a difference for the Sugar, but not for the display+Pi.
Another thing to try: there is a file inky/eeprom.py which just uses I2C to read the eeprom of the display. You could try this in your Sugar setup vs display+Pi. This would tell us that at least I2C is working.
Just jumping in here to say that I am also encountering this issue. I am able to read the eeprom data in inky/eeprom.py
$ python eeprom.py
Display: 1600x1200
Color: spectra6
PCB Variant: 10.0
Display Variant: 21
Time: b’2025-09-26 09:14:11.3’
However, when I try and run the image.py example I get this
$ python3 /home/pi/inky/examples/spectra6/image.py --file image.jpg
Detected Spectra 6 13.3 1600 x 1200 (EL133UF1)
And it just hangs here
Thanks, so I2C is working. Some next steps:
  • change the SPI speed if not already done
  • instrument the driver with a number of print-statements
The first item might or might not help. See the linked post for details. For the second item: the correct driver file is inky/inky_el133uf1.py. One big candidate for the hang is the the busy-pin. The driver waits for this pin to go low. So I would certainly add some prints to _busy_wait() and to all occurences before/after this method call. The important stuff is happening in _update().
If I understand the docs for the PiSugar3 correctly, it only uses I2C. And it connects from below with pogo-pins. So I see no reason why the busy-pin should not work. But you never know.
For what it’s worth I too am experiencing this issue (13.3" inky impression with rpi0 2w). @Dountill have you managed to determine a root cause?
I set up a logic probe on the SPI pins and compared the working case (USB power) to the sporadically non-working case (pisugar Battery power). I observed that when the display fails to update under battery power the spi interface is acting strangely: MISO, CSB_S and not(INKY_CS) all seem to go high during boot. I’m going to keep playing around with the board but I’m suspecting that there may be some pull-up/pulldown resistors needed to guarantee the eink power on state while booting via the sugarpi? I also see that the 3v3 rail of the raspberry pi seems to rise a lot slower under pisugar battery power versus USB power.
Very interesting findings, thanks for sharing. not(INKY_CS) going high at boot could indeed confuse the driver.
You could try to drive the relevant GPIOs at boot using entries in config.txt, see https://www.raspberrypi.com/documentation/computers/config_txt.html#gpio-control
Not sure if this would cause other issues or would need a fix for the driver (reclaiming the gpios or at least resetting them to what is needed).
I hit what might be the same problem, and fixed it with a 1000 uF capacitor between the 3V3 and GND rails. See Inky Impression 13.3" + Witty Pi + Raspberry Pi Zero W2 not working - #25 by canton7.
