Inky phat inverting colours at end of program
Using inkyPHAT on RPI Zero with below code I created to see if I can create some bar graphs.
I’m puzzled on why it draws inverted? at the end of the program it corrects with BLACK background and WHITE line?
from PIL import Image, ImageDraw
from inky.auto import auto
def draw_line(line_width, speed):
# Initialize the InkyPHAT object
inky_display = auto()
inky_display.set_border(inky_display.BLACK)
# Create a new PIL image object with a black background
img = Image.new("P", (inky_display.WIDTH, inky_display.HEIGHT), inky_display.BLACK)
draw = ImageDraw.Draw(img)
inky_display.set_image(img)
inky_display.show()
time.sleep(1)
# Calculate the y-coordinate for the center of the line
y_center = inky_display.HEIGHT // 2
# Loop to animate the drawing of the line
for x in range(0, inky_display.WIDTH, speed):
    # Draw a vertical line segment with the specified width at the current position
    draw.rectangle((x, y_center - line_width // 2, x + speed, y_center + line_width // 2), fill=inky_display.WHITE)
    # Update the display every 10 iterations to speed up the animation
    if x % 10 == 0:
        # Set the image on the InkyPHAT display and show it
        inky_display.show()
    # Pause before drawing the next segment
    time.sleep(0.01)  # Reduced sleep time
Get the line width and speed as input from the user
line_width = int(input("Enter the width of the line in pixels: "))
speed = int(input("Enter the speed of the animation (1 for fastest, higher for slower): "))
Call the function with the user-specified values
