Hi, im new to all this and im trying to create a QR image using the example script from the original inky script and i can’t seem to get it to work.
I keep getting
ValueError: cannot determine region size; use 4-item box
could anyone lend me a hand on where I even begin?
Code:
#!/usr/bin/env python3
import sys
import os
from PIL import Image
import qrcode
from inky.auto import auto
inky_display = auto()print(“”“Inky pHAT: QR Code
Display a QR Code on Inky pHAT!
Usage: {} ”“”.format(sys.argv[0]))Max length is 152
text = “”“In the old #BILGETANK we’ll keep you in the know,
In the old #BILGETANK we’ll fix your techie woes.
https://www.youtube.com/pimoroniltd”“”if len(sys.argv) < 2:
print(“”“Valid colours for v2 are: red, yellow or black
Inky pHAT v1 is only available in red.”“”.format(sys.argv[0]))
sys.exit(1)colour = sys.argv[1]
if len(sys.argv) > 2:
text = sys.argv[2]class InkyQR(qrcode.image.base.BaseImage):
def new_image(self, **kwargs):
self.offset_x = kwargs.get(“offset_x”, None)
self.offset_y = kwargs.get(“offset_y”, None)if self.pixel_size - (self.border * 2) > min(inky_display.WIDTH, inky_display.HEIGHT): print("QR code is too large for Inky pHAT, it probably wont scan! Try `box_size=1`") if self.offset_x is None: self.offset_x = (inky_display.WIDTH // 2) - (self.pixel_size // 2) if self.offset_y is None: self.offset_y = (inky_display.HEIGHT // 2) - (self.pixel_size // 2) box = (self.offset_x, self.offset_y, self.offset_x + self.pixel_size - 1, self.offset_y + self.pixel_size - 1) inky_display.rectangle(box, fill=inky_display.WHITE) def pixel_box(self, row, col): x = (col + self.border) * self.box_size y = (row + self.border) * self.box_size x += self.offset_x y += self.offset_y return [(x, y), (x + self.box_size - 1, y + self.box_size - 1)] def drawrect(self, row, col): box = self.pixel_box(row, col) inky_display.rectangle(box, fill=inky_display.BLACK)
inky_display.set_image(“/home/pi/Pimoroni/inky/examples/phat/resources/empty-backdrop.png”)
qr = qrcode.QRCode(
version=1,
box_size=2,
border=2,
image_factory=InkyQR
)qr.add_data(text)
qr.make(fit=True)
qr.make_image()inky_display.show()
