Hello!
Finally got to play with the inkyphat I bought last year, but having little luck.
Started from a fresh raspbian installation and followed the steps on https://github.com/pimoroni/inky
clean.py worked well
but then:
pi@raspberrypi : ~/inky/examples ** python name-badge.py --type phat --colour yellow
File "name-badge.py", line 6, in <module>
from font_hanken_grotesk import HankenGroteskBold, HankenGroteskMedium
ImportError: No module named font_hanken_grotesk
**pi@raspberrypi** : **~/inky/examples
What am I doing wrong?
Thanks!
Yep. Same here. Pi Zero W. Latest updates as of today.
Similarly, the weather example is also missing fonts:
ModuleNotFoundError: No module named ‘font_fredoka_one’
I’m guessing i just need to work out how to install them, but it looks like the docs need updating, or the installer.
I found this line in the weather-phat.py script. Running it appeared to install the fonts needed for the weather script to work.
pip3 install geocoder requests font
EDIT
If you need the fonts installing for the first name badge example, run these:
pip3 install font_hanken_grotesk
pip3 install font_intuitive
Also, the examples further down the page don’t work as they are missing the .show() commands needed to actually update the screens.
Once you’ve finished example, update the screen with a inky_display.show() and it should then update.
e.g.
from inky.auto import auto
inky_display = auto()
inky_display.set_border(inky_display.BLACK)
inky_display.show()
I’m using BLACK, not white in my example because on the black and white one I have, using white just shows an entirely white screen meaning it doesn’t look like it’s working at all…
Next issue. The crontab examples in the getting started doc (Getting Started with Inky pHAT) don’t work. Presumably some missing info somewhere. (They just don’t seem to run at all!)
EDIT:
Yeah, it’s the addition of the virtual environment which causes the example to fail. Instead of running the python command directly, instead have it run a bash script. In that script add the command for changing to the correct environment before running the python script. Then call that (after making the script executable)
#!/bin/bash
source ~/.virtualenvs/pimoroni/bin/activate
cd /home/pi/inky/examples/
python phat/weather-phat.py
make the script executable:
chmod +x <scriptname>
add to crontab:
*/5 * * * * bash /home/pi/weatherscript.sh >> /home/pi/inkyPhat-cron.log 2>&1
(that runs it every 5mins from a home dir called “pi” and sends output to a log file in that directory)
