Intelligent access control based on ESP32 and LCD
Required materials
Realized function
  1. card registration.
  2. username and password registration.
  3. card swipe to unlock the electronic lock.
  4. User name and password to unlock the electronic lock.
Connection diagram
GUI design
code sharing
import mfrc522
import _thread
from os import uname
from machine import Pin, UART
#from pyb import UART
#import machine
suos = Pin(32,Pin.OUT)
uart2 = UART(2, baudrate=115200, rx=16,tx=17,timeout=10)
ESP32_HSPI_CLOCK = 14
ESP32_HSPI_SLAVE_SELECT = 15
ESP32_HSPI_MISO = 12
ESP32_HSPI_MOSI = 13
ESP32_MFRC522_RST = 5
rx3 = []
rx_name = []
user_id_flag = False
password_flag = False
temp_id = ''
temp_mima = ''
personnel_id = {'zbw':[236,230,169,47],'lbw':[19,165,93,4]}
personnel_ps = {'zbw':'zbw3366','lbw':'lbwnb'}
admin_password = ('yyds')
button_cmd = [16,1]
edit1_cmd = [16,112]
edit2_cmd = [16,113]
edit3_cmd = [16,114]
if uname()[0] == 'esp32':
	rdr = mfrc522.MFRC522(ESP32_HSPI_CLOCK, ESP32_HSPI_MOSI, ESP32_HSPI_MISO, ESP32_MFRC522_RST, ESP32_HSPI_SLAVE_SELECT)
def do_write():
	try:
		(stat, tag_type) = rdr.request(rdr.REQIDL)
		if stat == rdr.OK:
			(stat, raw_uid) = rdr.anticoll()
			if stat == rdr.OK:
				print("New card detected")
				print("  - tag type: 0x%02x" % tag_type)
				print("  - uid : 0x%02x%02x%02x%02x" % (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3]))
				print("")
				if rdr.select_tag(raw_uid) == rdr.OK:
					key = [0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
					if rdr.auth(rdr.AUTHENT1A, 8, key, raw_uid) == rdr.OK:
						stat = rdr.write(8, b"\x00\x53\x00\x54\x00\x4F\x00\x4E\x00\x45\x0a\x0b\x0c\x0d\x0e\x0f")
						rdr.stop_crypto1()
						if stat == rdr.OK:
							print("Data written to card")
						else:
							print("Failed to write data to card")
					else:
						print("Authentication error")
				else:
					print("Failed to select tag")
	except KeyboardInterrupt:
		print("write error")
def do_read():
		try:
			if stat == rdr.OK:
				if stat == rdr.OK:
					print (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3])
					print("")
							print("Address 8 data: %s" % rdr.read(8))
							for ps in personnel_id:
								if raw_uid[0:4:1] == personnel_id.get(ps):
									suos.value(1)
									print(ps)
									uart_write(ps, *raw_uid[0:4:1])
									time.sleep(3)
									uart2.sendbreak()
									break
							rdr.stop_crypto1()
							time.sleep(3)
							suos.value(0)
						else:
					else:
			if uart2.any()>1:
				rx2 = []
				data_name2 = ''
				bin_data = uart2.read(40)
				uart2.sendbreak()
				rx1 = list(bin_data)
				for item in rx1:
					rx2.append(chr(item))
				print(rx2)
				if rx1[3:5:1] == button_cmd:
					data_name_len = rx1[6] - 1
					data_name = rx2[7:data_name_len+7:1]
					data_name2 = ''.join(data_name)
					print(data_name2)
					if data_name2 == 'back3':
						return
			print("read error")
def do_read2 (idd):
	print(idd)
		try:
			if stat == rdr.OK:
				if stat == rdr.OK:
					print("")
							personnel_id[idd] = raw_uid[0:4:1]
							uart_write3(*raw_uid[0:4:1])
							rdr.stop_crypto1()
						else:
					else:
			if uart2.any()>1:
				rx2 = []
				data_name2 = ''
				uart2.sendbreak()
				for item in rx1:
					print(data_name2)
				if data_name2 == 'back1':
					return
			print("read error")
def uart_write(text, *ids):
#	print(text, *ids)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"'+str(text)+'"}>ET')
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"'+str(ids)+'"}>ET')
	uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":true}>ET')
	time.sleep(3)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"''"}>ET')
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"''"}>ET')
	uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":false}>ET')
def uart_write2(text,text2):
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text+'"}>ET')
	time.sleep(3)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text2+'"}>ET')
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit2","text":"''"}>ET')
def uart_write3(*id2):
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+str(id2)+'"}>ET')
	time.sleep(3)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"''"}>ET')
def uart_write4(text,text2):
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text+'"}>ET')
	time.sleep(1)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text2+'"}>ET')
	time.sleep(1)
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit3","text":"''"}>ET')
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit4","text":"''"}>ET')
	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit7","text":"''"}>ET')
def uart_write5():
	time.sleep(3)
def card_zhuce():
		if uart2.any():
			user_id = ''
			password = ''
			rx2 = []
			rx_num = 0
			uart2.sendbreak()
			for item in rx1:
				rx_num += 1
			data_end = rx_num-5
			data_id_st = rx2[8:13:1]
			data_id_st2 = ''.join(data_id_st)
			print(data_id_st2)
			if data_id_st2 == 'edit1':
				data_id_st3 = rx2[15:data_end:1]
				data_id_st4 = ''.join(data_id_st3)
				print(data_id_st4)
				if data_id_st4 != '':
					name = True
			elif data_id_st2 == 'edit2':
				data_id_st5 = rx2[15:data_end:1]
				data_id_st6 = ''.join(data_id_st5)
				if data_id_st6 == admin_password:
					admin = True
					uart_write2('Verification passed!','Please place the card!')
					do_read2(data_id_st4)
					return
def mima_zuce():
	temp_id3 = ''
	temp_mima3 = ''
		if uart2.any():
			user_id = ''
			password = ''
			rx2 = []
			rx_num = 0
#			data_end = 0
			uart2.sendbreak()
			for item in rx1:
				rx_num += 1
#				if (rx2[rx_num] == 'T') and (rx2[rx_num-1] == 'E') and (rx2[rx_num-2] == '>'):
#					break
			data_end = rx_num-5
			print(data_id_st2)
				print(data_name2)
				if data_name2 == 'back2':
					return
			if data_id_st2 == 'edit3':
				print(data_id_st4)
				user_id_flag = True
				temp_id3 = data_id_st4
#				personnel_ps[temp_id] = raw_uid[0:4:1]
			elif data_id_st2 == 'edit4':
				print(data_id_st6)
#				if personnel_ps.get(temp_id) == data_id_st6:
				password_flag = True
				temp_mima3 = data_id_st6
#					personnel_ps[temp_id] = password_flag
#			print(rx2,user_id_flag,password_flag)
			elif data_id_st2 == 'edit7':
				if (data_id_st6 == admin_password) and (password_flag == True) and (user_id_flag == True):
					admin = True
					personnel_ps[temp_id3] = temp_mima3
					uart_write4('Verification passed!','login was successful!')
def password_loin():
	temp_id2 = ''
	temp_mima = ''
		if uart2.any():
			user_id = ''
			password = ''
			rx2 = []
			rx_num = 0
#			data_end = 0
			uart2.sendbreak()
			for item in rx1:
				rx_num += 1
#					break
			data_end = rx_num-5
			print(data_id_st2)
				print(data_name2)
				if data_name2 == 'back4':
					return
			if data_id_st2 == 'edit5':
				print(data_id_st4)
				if data_id_st4 in personnel_ps:
					user_id_flag = True
					temp_id2 = data_id_st4
			elif data_id_st2 == 'edit6':
				print(data_id_st6)
				print(temp_id2)
				print(personnel_ps)
				if personnel_ps.get(temp_id2) == data_id_st6:
					print(user_id_flag,password_flag)
					if (password_flag == True) and (user_id_flag == True):
						uart_write(temp_id2,temp_id2)
						suos.value(1)
						uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":true}>ET')
						uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit5","text":"''"}>ET')
						uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit6","text":"''"}>ET')
						time.sleep(3)
#						uart_write('student','')
						suos.value(0)
						uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":false}>ET')
						uart2.sendbreak()
	if uart2.any()>1:
		rx2 = []
		data_name2 = ''
#		time.sleep(1)
		uart2.sendbreak()
#		time.sleep(1)
		for item in rx1:
		print(rx2)
			print(data_name2)
			if data_name2 == 'card1':
				card_zhuce()
			elif data_name2 == 'password1':
				mima_zuce()
			elif data_name2 == 'card2':
				do_read()
			elif data_name2 == 'password2':
				password_loin()
Video demo
