Is it possible to control an SD card over SPI with the tiny2040?
Is it possible to control a SD card over SPI with the tiny2040? If so, what pins do I connect?
I don’t have a definitive answer, I haven’t tried to do it.
I do have a Tiny2040, but haven’t done a whole lot with it if I’m honest.
I’d start with the pinout and what control signals your SD card reader / writer needs.
Do you have an SD card reader writer in mind?
I have this one
https://www.amazon.com/Micro-SDIO-Card-Breakout-Board/dp/B09K6XVS9R/
Digikey have a guide for doing it with the Pico here. The Tiny2040 exposes a SPI bus, so as long as you map to the right pins it should work.
If you can solder you just need the micro SD card adaptor. You can find out how about 80% of the way through. Just move the SPI pins as necessary.
@Tonygo2 I knew somebody here had done that, and posted a picture. I was also pretty sure it was you, couldn’t find the thread though. Thanks for posting that info.
