I noticed in the keybow2040.py code there is what looks like an unfinished bit of code commented out for rotating the key/led numbering.
I didn’t have time to dive into it, so I went with a more direct editing method that I’d though I’d share
With the cable at the top/away the default numbering goes from 0 bottom to 3 top, left column first
To change the order to 0 lef to 3 right, top row first (english reading order) two changes must be made
Change #1
# Old code in /lib/keybow2040.py
_PINS = [board.SW0,
board.SW1,
board.SW2,
board.SW3,
board.SW4,
board.SW5,
board.SW6,
board.SW7,
board.SW8,
board.SW9,
board.SW10,
board.SW11,
board.SW12,
board.SW13,
board.SW14,
board.SW15]
becomes
# New code in /lib/keybow2040.py
_PINS = [board.SW3,
board.SW7,
board.SW11,
board.SW15,
board.SW2,
board.SW6,
board.SW10,
board.SW14,
board.SW1,
board.SW5,
board.SW9,
board.SW13,
board.SW0,
board.SW4,
board.SW8,
board.SW12]
and Change #2
def number_to_xy(number):
# Convert a number to an x/y coordinate.
# uncomment for Bottom left = 0, up = 1+
x = number % 4
y = number // 4
return (x, y)
becomes
x = (15-number) // 4
y = number % 4
return (x, y)
similar manipulations can get you other orientations
I’m not sure why the second change is necessary but I believe it’s because the LEDs are enumerated by the I2C library. if I get around to it I may write a function that will allow arbitrary numbering of keys to allow more options (I’m thinking any arbitrary layout)
