Micro Dot Phat GPIO pins
Which GPIOs are used by the Micro Dot pHAT? Aside from SDA1 and SCL1 (and power), are any other pins used? I’d like to have a go at running two displays off one RPi. I suppose it’s not possible to modify the I2C addresses (and the datasheet seems to say there are only 4 addresses available anyway), so I’ll need to repurpose the EEPROM I2C bus for the second display. I’d just like to check there are no other pins which need connecting.
thanks, -Tim
That’s it- just I2C, 5V and ground.
Thanks…
