I’ve built a mini-smart mirror that uses a BME280 sensor to read temperature, pressure and humidity and then displays the stats on the Micro Dot pHAT (it’ll soon be in the MagPi btw), but I’m struggling to get the MDpHAT to show the time as well.
To add more to the mix, I’m also pushing data to Beebotte to track the readings, but I’m also integrating Pushover notifications to warn us if the temperature rises above a set reading (the setup is in our baby son’s nursery).
I have got the majority of the above working, except displaying the time. I’m looking to display temperature, humidity (pressure is not that relevant really) then the time at 5 second intervals - i.e. temp -> (5s) -> humidity -> (5s) -> time (5s) -> repeat.
This is my code so far and I suspect the issue is around when the clock is called, but any help would be greatly appreciated:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import bme280
import datetime
import sys
import threading
import httplib, urllib
from microdotphat import write_string, set_decimal, clear, show
from beebotte import *
### Replace CHANNEL_TOKEN with that of your Beebotte channel
### and YOUR_CHANNEL_NAME_HERE with the channel you create
bbt = BBT(token = 'CHANNEL_TOKEN')
chanName = "YOUR_CHANNEL_NAME_HERE"
### Change Beebotte channel name as suits you - in this instance, it is called BME280.
temp_resource = Resource(bbt, chanName, 'temperature')
pressure_resource = Resource(bbt, chanName, 'pressure')
humidity_resource = Resource(bbt, chanName, 'humidity')
# Sends data to your Beebotte channel
def beebotte():
temp_resource.write(round(temperature,1))
pressure_resource.write(round(pressure,0))
humidity_resource.write(round(humidity,0))
time.sleep(900) # 15 mins to prevent maxing API limit
# Experimental! Clock - may not work yet!
# Display time on Micro Dot pHAT for set time
showClock = 5 # Seconds
# Function for the clock
def clock():
clockEndTime = time.time() + showClock
while time.time() < clockEndTime:
clear()
t = datetime.datetime.now()
if t.second % 2 == 0:
set_decimal(2, 1)
set_decimal(4, 1)
else:
set_decimal(2, 0)
set_decimal(4, 0)
write_string(t.strftime('%H%M%S'), kerning=False)
show()
time.sleep(0.05)
# Experimental! Pushover notifications - should work
def pushover():
conn = httplib.HTTPSConnection("api.pushover.net:443")
conn.request("POST", "/1/messages.json",
urllib.urlencode({
"token": "APP_TOKEN", # Insert app token here
"user": "USER_TOKEN", # Insert user token here
"html": "1",
"title": "High temperature!",
"message": "It is "+str(temperature)+ "°C in the nursery!",
"url": "https://beebotte.com/dash/RANDOM_ID_HERE",
"url_title": "View Beebotte dashboard",
"sound": "siren",
}), { "Content-type": "application/x-www-form-urlencoded" })
conn.getresponse()
# Display stats on the Micro Dot pHAT
def microdot():
clear()
write_string( "%.1f" % temperature + "C", kerning=False)
show()
time.sleep(5)
# Uncomment to display pressure if needed
#clear()
#write_string( "%.0f" % pressure + "hPa", kerning=False)
#show()
#time.sleep(5)
clear()
write_string( "%.0f" % humidity + "% RH", kerning=False)
show()
time.sleep(5)
clock()
try:
# Get the first reading from the BME280 sensor
temperature,pressure,humidity = bme280.readBME280All()
# Start the Beebotte function as a thread so it works in the background
beebotte_thread = threading.Thread(target=beebotte)
beebotte_thread.daemon = True
beebotte_thread.start()
# Run a loop to collect data and display it on the Micro Dot pHAT
# and send notifications via Pushover if it is too hot
if temperature >= 26:
pushover()
else:
continue
microdot()
# Attempt to exit cleanly - not quite there, needs work!
except (KeyboardInterrupt, SystemExit):
sys.exit()
pass
If it helps, my GitHub repo is here so happy to work in there if needed: https://github.com/raspberrycoulis/bme280-pi
Thanks!
