This may not be the proper place to post this, but this is by far my most favourite forum to hang out on. :) So here goes.
Is anybody else totally dumbfounded by the lack of USB HID in Micro Python?
I just don’t get why this isn’t there yet? To me it’s very frustrating to have to go the Circuit Python route to get this support. It works, sort of kind of?
Well, MP does have HID, but not on every port. It is probably not trivial to implement the whole protocol on MCU side.
The best thing to do when you encounter crashes is to open an issue at CP. These guys are all very helpful and if it crashes regularly, the chances are high they can reproduce and fix it.
I guess I could go that route? Going to be a pain to sort out though, I’m thinking? It works fine from Thonny, if I run my code from there. I had to put in a 30 second delay before my code runs or it won’t work as a USB HID device. Even then, more often than not it just stops working after a couple of button presses. Push reset and its good to go after that for the rest of that session on my PC.
I’d likely have to try and use the debug port?
Thing is, the RGB keypad / hardware is Pimoroni.
And all the software addons / libraries etc used to make it work are Adafruits.
It works flawless in Micro Python with no glitches, it just won’t work as a USB Hid device.
Have you verified that the extra delay is not forced by your PC/operating system? Same for the glitches you experience. You could check the system-log to see if there are any error-messages regarding the keyboard that your device emulates. Also, you should rule out any problems with your cables. But given your experience, you probably did that already.
