Need to run two Pico Display Packs
Having issues tryin g to get it to work on my 320x240 Display Pack V2 though? Landscape mode works but Portrait doesn’t, text is all garbled? All is fine on the smaller 240x135 Display Pack though?
 # This example borrows a CircuitPython hsv_to_rgb function to cycle through some rainbows on Pico Display's screen and RGB LED . If you're into rainbows, HSV (Hue, Saturation, Value) is very useful!
import st7789
import utime
#display = st7789.ST7789(width=240, height=135, slot=0) # Display Pack landscape works
#display = st7789.ST7789(width=135, height=240, slot=0) # Display Pack portrait works
#display = st7789.ST7789(width=320, height=240, slot=0) # Display Pack V2 landscape works
display = st7789.ST7789(width=240, height=320, slot=0) # Display Pack V2 portrait didn't work
print(display)
display.set_backlight(1.0)
# From CPython Lib/colorsys.py
def hsv_to_rgb(h, s, v):
    if s == 0.0:
        return v, v, v
    i = int(h * 6.0)
    f = (h * 6.0) - i
    p = v * (1.0 - s)
    q = v * (1.0 - s * f)
    t = v * (1.0 - s * (1.0 - f))
    i = i % 6
    if i == 0:
        return v, t, p
    if i == 1:
        return q, v, p
    if i == 2:
        return p, v, t
    if i == 3:
        return p, q, v
    if i == 4:
        return t, p, v
    if i == 5:
        return v, p, q
h = 0
    h += 1
    r, g, b = [int(255 * c) for c in hsv_to_rgb(h / 360.0, 1.0, 1.0)]  # rainbow magic
    #display.set_led(r, g, b)  # Set LED to a converted HSV value
    display.set_pen(r, g, b)  # Set pen to a converted HSV value
    display.clear()           # Fill the screen with the colour
    display.set_pen(0, 0, 0)  # Set pen to black
    #display.text("pico disco!", 10, 10, 240, 6)  # landscape
    display.text("pico disco!", 10, 10, 135, 4)  # potrait
    display.update()          # Update the display
    utime.sleep(1.0 / 60)
