When will the Pico Display Pack 2.0 be available?
Is there a version without the buttons?
The buttons cannot be used if the display is mounted in a project box and only make the board wider. This means the buttons I had to add are mounted farther from the display.
On another note: I am using Thonny a simple SDK for programming. The pico program memory is limited to about 500 lines, is there any way to increase that?
The problem here is that these large displays with plenty of pixels need a very large display buffer which takes up memory. So, basically it is a play off between plenty of colours, number of pixels and plenty of program space.
Life is all about balance and this is a three ring Venn diagram!
Have fun
