NVMe Base for Raspberry Pi 5 stopped working
I have one of your NVMe Base for Raspberry Pi 5, Order #PI696028.Been using it for several month’s then today it stopped working, I got my pi5 backup using an SD card.
I have check the seatting of the cable and it looks OK.
How can I determine which part is bad?
Thanks for your help
Have you tried doing a fresh setup / reinstall? Start over like you just took it out of the shipping box.
that does make sense, but I would lose the data n the ssd
rich@PI5-Server:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 119.1G 0 disk
├─mmcblk0p1 179:1 0 512M 0 part /boot/firmware
└─mmcblk0p2 179:2 0 118.6G 0 part /
rich@PI5-Server:~ $
the lsbk command does see the ssd
sorry i read 500mb as 500 gb
@guru is likely the guy to ask what to do now.
I’m a Linux noob, so my Linux skills are lacking.
ls /dev/nvme0
ls: cannot access \'/dev/nvme0\': No such file or directory
the cable is well seated.
What now??
What now??
If you’ve checked both ends of the cable, checked the NVME is still seated properly. Blown in the ports/slots for good measure, then it’s like that the Pi, NVMe base or NVMe have a problem.
Check dmesg or journatlctl for error messages from boot. They might reveal if the drive was spotted, but couldn’t be started up, or if the system didn’t see the drive at all. Or if other errors are going on.
If there’s nothing that helps after that, get in touch with support@pimoroni.com. Usually we’ll replace the NVMe Base as a first port of call and see if that brings things back to life.
sorry for the big file but did not find a way to attach a file. Two parts because of size
rich@PI5-Server:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[ 0.000000] Linux version 6.6.31+rpt-rpi-2712 (serge@raspberrypi.com) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29)
[ 0.000000] KASLR enabled
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000002000000…0x0000000015ffffff (327680 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000000000000…0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[ 0.000000] OF: reserved mem: 0x000000003fd16600…0x000000003fd16637 (0 KiB) nomap non-reusable nvram@0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000007ffff]
[ 0.000000] node 0: [mem 0x0000000000080000-0x000000003fbfffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] On node 0, zone DMA: 256 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 14 pages/cpu s183976 r8192 d37208 u229376
[ 0.000000] pcpu-alloc: s183976 r8192 d37208 u229376 alloc=14*16384
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe smsc95xx.macaddr=D8:3A:DD:C0:6E:5B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=20448d2c-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=US
[ 0.000000] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260864
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 3792320K/4190208K available (13440K kernel code, 2222K rwdata, 4288K rodata, 5056K init, 1213K bss, 70208K reserved, 327680K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 43180 entries in 43 pages
[ 0.000000] ftrace: allocated 43 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000164] Console: colour dummy device 80x25
[ 0.000168] printk: console [tty1] enabled
[ 0.000330] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000338] pid_max: default: 32768 minimum: 301
[ 0.000362] LSM: initializing lsm=capability,integrity
[ 0.000421] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[ 0.000436] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[ 0.000775] cgroup: Disabling memory control group subsystem
[ 0.001186] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.001214] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.001239] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.001300] rcu: Hierarchical SRCU implementation.
[ 0.001304] rcu: Max phase no-delay instances is 1000.
[ 0.001914] EFI services will not be available.
[ 0.001988] smp: Bringing up secondary CPUs …
[ 0.002144] Detected PIPT I-cache on CPU1
[ 0.002185] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[ 0.002363] Detected PIPT I-cache on CPU2
[ 0.002395] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[ 0.002555] Detected PIPT I-cache on CPU3
[ 0.002585] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[ 0.002610] smp: Brought up 1 node, 4 CPUs
[ 0.002628] SMP: Total of 4 processors activated.
[ 0.002633] CPU features: detected: 32-bit EL0 Support
[ 0.002636] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.002641] CPU features: detected: Common not Private translations
[ 0.002645] CPU features: detected: CRC32 instructions
[ 0.002649] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.002653] CPU features: detected: LSE atomic instructions
[ 0.002657] CPU features: detected: Privileged Access Never
[ 0.002660] CPU features: detected: RAS Extension Support
[ 0.002664] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.002700] CPU: All CPU(s) started at EL2
[ 0.002704] alternatives: applying system-wide alternatives
[ 0.004452] devtmpfs: initialized
[ 0.007455] Enabled cp15_barrier support
[ 0.007464] Enabled setend support
[ 0.007531] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.007541] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[ 0.008292] pinctrl core: initialized pinctrl subsystem
[ 0.008430] DMI not present or invalid.
[ 0.008588] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.009169] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.009218] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.009269] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.009289] audit: initializing netlink subsys (disabled)
[ 0.009338] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[ 0.009457] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.009469] cpuidle: using governor menu
[ 0.009536] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.009566] ASID allocator initialised with 32768 entries
[ 0.009892] Serial: AMBA PL011 UART driver
[ 0.010882] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[ 0.011222] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[ 0.011236] printk: console [ttyAMA10] enabled
[ 0.735885] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-06-05T15:41:49, variant start_cd
[ 0.749940] raspberrypi-firmware soc:firmware: Firmware hash is 6fe0b09100000000000000000000000000000000
[ 0.765848] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.772934] Modules: 0 pages in range for non-PLT usage
[ 0.772935] Modules: 129412 pages in range for PLT usage
[ 0.782743] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[ 0.795732] iommu: Default domain type: Translated
[ 0.800653] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.806941] SCSI subsystem initialized
[ 0.810745] usbcore: registered new interface driver usbfs
[ 0.816259] usbcore: registered new interface driver hub
[ 0.821598] usbcore: registered new device driver usb
[ 0.826751] pps_core: LinuxPPS API ver. 1 registered
[ 0.831733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.840907] PTP clock support registered
[ 0.845116] vgaarb: loaded
[ 0.847923] clocksource: Switched to clocksource arch_sys_counter
[ 1.067528] VFS: Disk quotas dquot_6.6.0
[ 1.071481] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[ 1.078586] FS-Cache: Loaded
[ 1.081513] CacheFiles: Loaded
[ 1.085906] NET: Registered PF_INET protocol family
[ 1.090897] IP idents hash table entries: 65536 (order: 5, 524288 bytes, linear)
[ 1.099581] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, linear)
[ 1.108165] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[ 1.115943] TCP established hash table entries: 32768 (order: 4, 262144 bytes, linear)
[ 1.124028] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, linear)
[ 1.132211] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.138883] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, linear)
[ 1.146363] UDP hash table entries: 2048 (order: 2, 65536 bytes, linear)
[ 1.153142] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, linear)
[ 1.160404] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.166226] RPC: Registered named UNIX socket transport module.
[ 1.172172] RPC: Registered udp transport module.
[ 1.176891] RPC: Registered tcp transport module.
[ 1.181610] RPC: Registered tcp-with-tls transport module.
[ 1.187115] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.193590] PCI: CLS 0 bytes, default 64
[ 1.197669] kvm [1]: IPA Size Limit: 40 bits
[ 1.201976] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[ 1.201983] Trying to unpack rootfs image as initramfs…
[ 1.210737] kvm [1]: vgic interrupt IRQ9
[ 1.220087] kvm [1]: VHE mode initialized successfully
[ 1.225723] Initialise system trusted keyrings
[ 1.230301] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 1.236797] zbud: loaded
[ 1.239540] NFS: Registering the id_resolver key type
[ 1.244625] Key type id_resolver registered
[ 1.248822] Key type id_legacy registered
[ 1.252859] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.259588] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.267159] F2FS not supported on PAGE_SIZE(16384) != 4096
[ 1.272739] Key type asymmetric registered
[ 1.276852] Asymmetric key parser ‘x509’ registered
[ 1.281769] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.289258] io scheduler mq-deadline registered
[ 1.293812] io scheduler kyber registered
[ 1.297853] io scheduler bfq registered
[ 1.304220] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[ 1.313408] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[ 1.321161] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[ 1.328920] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[ 1.336676] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[ 1.345826] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[ 1.388758] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.395698] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[ 1.406350] serial serial0: tty port ttyS0 registered
[ 1.412013] iproc-rng200 107d208000.rng: hwrng registered
[ 1.417535] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[ 1.426142] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[ 1.435295] brd: module loaded
[ 1.439975] loop: module loaded
[ 1.443326] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.451323] Loading iSCSI transport class v2.0-870.
[ 1.454388] Freeing initrd memory: 17168K
[ 1.457265] usbcore: registered new device driver r8152-cfgselector
[ 1.466647] usbcore: registered new interface driver r8152
[ 1.472161] usbcore: registered new interface driver lan78xx
[ 1.477848] usbcore: registered new interface driver smsc95xx
[ 1.483688] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.489478] dwc_otg: FIQ enabled
[ 1.489479] dwc_otg: NAK holdoff enabled
[ 1.489481] dwc_otg: FIQ split-transaction FSM enabled
[ 1.489483] Module dwc_common_port init
[ 1.489624] usbcore: registered new interface driver uas
[ 1.494963] usbcore: registered new interface driver usb-storage
[ 1.501111] mousedev: PS/2 mouse device common for all mice
[ 1.515117] rpi-rtc soc:rpi_rtc: registered as rtc0
[ 1.521539] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:00:36 UTC (36)
[ 1.529757] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[ 1.536317] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.545135] sdhci: Secure Digital Host Controller Interface driver
[ 1.551342] sdhci: Copyright(c) Pierre Ossman
[ 1.555754] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.561635] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.567702] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 1.574179] hid: raw HID events driver (C) Jiri Kosina
[ 1.579360] usbcore: registered new interface driver usbhid
[ 1.584953] usbhid: USB HID core driver
[ 1.589143] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[ 1.597708] NET: Registered PF_PACKET protocol family
[ 1.602810] Key type dns_resolver registered
[ 1.612660] registered taskstats version 1
[ 1.616834] Loading compiled-in X.509 certificates
[ 1.623988] Key type .fscrypt registered
[ 1.627925] Key type fscrypt-provisioning registered
[ 1.634037] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[ 1.641321] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@120000, using [bus 00-ff]
[ 1.650420] brcm-pcie 1000120000.pcie: MEM 0x1f00000000…0x1ffffffffb → 0x0000000000
[ 1.658723] brcm-pcie 1000120000.pcie: MEM 0x1c00000000…0x1effffffff → 0x0400000000
[ 1.667029] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000…0x1f003fffff → 0x0000000000
[ 1.675331] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000…0x0fffffffff → 0x1000000000
[ 1.684775] brcm-pcie 1000120000.pcie: Forcing gen 2
[ 1.689963] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[ 1.696432] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.701939] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[ 1.712510] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[ 1.723703] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[ 1.729762] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.736195] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.851928] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[ 1.858589] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[ 1.864631] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[ 1.870928] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[ 1.877225] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[ 1.883584] pci 0000:01:00.0: supports D1
[ 1.887605] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 1.903932] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.910582] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[ 1.917749] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[ 1.924916] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[ 1.932083] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[ 1.939250] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.944232] pci 0000:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]
[ 1.951399] pci 0000:00:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 1.959881] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 1.968419] pcieport 0000:00:00.0: enabling device (0000 → 0002)
[ 1.974573] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[ 1.980399] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[ 1.986075] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[ 1.995165] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[ 2.004432] rp1 0000:01:00.0: enabling device (0000 → 0002)
[ 2.010986] rp1 0000:01:00.0: chip_id 0x20001927
[ 2.020496] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 100
[ 2.048742] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 106 (d8:3a:dd:c0:6e:5b)
[ 2.059591] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[ 2.068161] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 2.073238] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[ 2.080935] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[ 2.089942] xhci-hcd xhci-hcd.0: irq 131, io mem 0x1f00200000
[ 2.095779] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 2.100850] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[ 2.108103] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[ 2.114266] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 2.122571] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.129829] usb usb1: Product: xHCI Host Controller
[ 2.134724] usb usb1: Manufacturer: Linux 6.6.31+rpt-rpi-2712 xhci-hcd
[ 2.141277] usb usb1: SerialNumber: xhci-hcd.0
[ 2.145849] hub 1-0:1.0: USB hub found
[ 2.149626] hub 1-0:1.0: 2 ports detected
[ 2.153787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 2.162100] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.169357] usb usb2: Product: xHCI Host Controller
[ 2.174251] usb usb2: Manufacturer: Linux 6.6.31+rpt-rpi-2712 xhci-hcd
[ 2.180871] usb usb2: SerialNumber: xhci-hcd.0
[ 2.185433] hub 2-0:1.0: USB hub found
[ 2.189204] hub 2-0:1.0: 1 port detected
[ 2.193423] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 2.198608] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[ 2.206302] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
part two
[ 2.215411] xhci-hcd xhci-hcd.1: irq 136, io mem 0x1f00300000
[ 2.221245] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 2.226318] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[ 2.233673] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[ 2.239820] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 2.248222] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.255474] usb usb3: Product: xHCI Host Controller
[ 2.260368] usb usb3: Manufacturer: Linux 6.6.31+rpt-rpi-2712 xhci-hcd
[ 2.267021] usb usb3: SerialNumber: xhci-hcd.1
[ 2.271575] hub 3-0:1.0: USB hub found
[ 2.275348] hub 3-0:1.0: 2 ports detected
[ 2.279486] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 2.287889] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.295144] usb usb4: Product: xHCI Host Controller
[ 2.300232] usb usb4: Manufacturer: Linux 6.6.31+rpt-rpi-2712 xhci-hcd
[ 2.306786] usb usb4: SerialNumber: xhci-hcd.1
[ 2.311336] hub 4-0:1.0: USB hub found
[ 2.315107] hub 4-0:1.0: 1 port detected
[ 2.319858] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 2.328241] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 2.336491] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 2.344562] platform 1000800000.codec: Adding to iommu group 0
[ 2.350435] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 2.358849] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 2.367076] platform 1000880000.pisp_be: Adding to iommu group 0
[ 2.373330] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 2.381204] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 2.389444] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[ 2.396538] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 2.405060] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[ 2.412329] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[ 2.419587] platform axi:gpu: Adding to iommu group 1
[ 2.424898] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[ 2.431977] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[ 2.439008] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 2.447569] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[ 2.454660] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[ 2.459883] pl011-axi 1f00030000.serial: cts_event_workaround enabled
[ 2.464168] mmc1: CQHCI version 5.10
[ 2.466660] 1f00030000.serial: ttyAMA0 at MMIO 0x1f00030000 (irq = 125, base_baud = 0) is a PL011 AXI
[ 2.480040] of_cfs_init
[ 2.482519] of_cfs_init: OK
[ 2.485600] clk: Disabling unused clocks
[ 2.503929] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[ 2.610062] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.616940] mmcblk0: mmc0:aaaa SR128 119 GiB
[ 2.622551] mmcblk0: p1 p2
[ 2.625459] mmcblk0: mmc0:aaaa SR128 119 GiB (quirks 0x00004000)
[ 2.662036] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[ 2.673286] Freeing unused kernel memory: 5056K
[ 2.677943] Run /init as init process
[ 2.681753] with arguments:
[ 2.681755] /init
[ 2.681756] with environment:
[ 2.681758] HOME=/
[ 2.681759] TERM=linux
[ 2.712363] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[ 2.813695] input: pwr_button as /devices/platform/pwr_button/input/input0
[ 2.821667] brcmstb-i2c 107d508200.i2c: @97500hz registered in interrupt mode
[ 2.830278] brcmstb-i2c 107d508280.i2c: @97500hz registered in interrupt mode
[ 2.874733] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
[ 2.875856] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[ 2.894883] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 2.903300] Registered IR keymap rc-cec
[ 2.907209] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[ 2.914515] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[ 2.923042] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
[ 2.932282] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.940667] Registered IR keymap rc-cec
[ 2.944575] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[ 2.951872] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
[ 2.960318] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
[ 2.969496] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.976617] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[ 2.983504] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[ 2.990655] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.998233] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.006247] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
[ 3.014960] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.023086] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.031213] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.037385] uart-pl011 107d001000.serial: no DMA platform data
[ 3.186407] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
[ 3.436788] systemd[1]: System time before build time, advancing clock.
[ 3.501940] NET: Registered PF_INET6 protocol family
[ 3.507307] Segment Routing with IPv6
[ 3.511017] In-situ OAM (IOAM) with IPv6
[ 3.545157] systemd[1]: systemd 252.26-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.578008] systemd[1]: Detected architecture arm64.
[ 3.585340] systemd[1]: Hostname set to .
[ 3.871660] systemd[1]: Queued start job for default target graphical.target.
[ 3.904550] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 3.912264] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 3.923040] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ 3.933960] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 3.945533] systemd[1]: Created slice user.slice - User and Session Slice.
[ 3.954453] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 3.967907] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 3.982420] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-20448d2c\x2d01.device - /dev/disk/by-partuuid/20448d2c-01…
[ 3.996615] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10…
[ 4.006071] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 4.017859] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[ 4.029197] systemd[1]: Reached target slices.target - Slice Units.
[ 4.038357] systemd[1]: Reached target swap.target - Swaps.
[ 4.046824] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 4.058201] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 4.069733] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 4.081525] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 4.092573] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 4.104362] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 4.114512] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 4.125450] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 4.136330] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 4.172031] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
[ 4.182918] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System…
[ 4.193591] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
[ 4.203772] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 4.223987] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock…
[ 4.235412] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout…
[ 4.246850] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
[ 4.259153] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs…
[ 4.270501] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod…
[ 4.281477] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm…
[ 4.291617] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 4.292128] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore…
[ 4.314194] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse…
[ 4.324866] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop…
[ 4.334448] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 4.334819] fuse: init (API version 7.39)
[ 4.360523] systemd[1]: Starting systemd-journald.service - Journal Service…
[ 4.371946] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules…
[ 4.383112] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
[ 4.394226] i2c_dev: i2c /dev entries driver
[ 4.395513] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
[ 4.412856] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 4.422778] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 4.433269] systemd[1]: Started systemd-journald.service - Journal Service.
[ 4.447999] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
[ 4.513268] systemd-journald[315]: Received client request to flush runtime journal.
[ 4.521928] systemd-journald[315]: File /var/log/journal/dc0900a33262482a8f011becd8d8ae3c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.928470] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[ 4.929476] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[ 4.929550] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[ 4.929671] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[ 4.931734] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[ 4.934012] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[ 4.934093] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[ 4.934161] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[ 4.934262] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[ 4.940434] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[ 4.969808] mc: Linux media interface: v0.10
[ 5.017366] videodev: Linux video capture interface: v2.00
[ 5.018306] Driver for 1-wire Dallas network protocol.
[ 5.028901] gpio-575 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.105571] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.115082] Loaded X.509 cert ‘benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf’
[ 5.115431] Loaded X.509 cert ‘romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328’
[ 5.115742] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.116084] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 5.118631] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 5.123306] pispbe 1000880000.pisp_be: pispbe_probe: HW version: 0x02252700
[ 5.123320] pispbe 1000880000.pisp_be: pispbe_probe: BatchStatus: 0x00000000
[ 5.123323] pispbe 1000880000.pisp_be: pispbe_probe: Status: 0x00000000
[ 5.123326] pispbe 1000880000.pisp_be: Register nodes for group 0
[ 5.123839] pispbe 1000880000.pisp_be: input device node registered as /dev/video20
[ 5.133593] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video21
[ 5.147307] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video22
[ 5.151850] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video23
[ 5.153094] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video24
[ 5.154784] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video25
[ 5.154843] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video26
[ 5.154884] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video27
[ 5.154918] pispbe 1000880000.pisp_be: config device node registered as /dev/video28
[ 5.155389] pispbe 1000880000.pisp_be: Register nodes for group 1
[ 5.155493] pispbe 1000880000.pisp_be: input device node registered as /dev/video29
[ 5.155580] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video30
[ 5.155641] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video31
[ 5.155672] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video32
[ 5.155705] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video33
[ 5.155739] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video34
[ 5.155771] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video35
[ 5.161769] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video36
[ 5.162792] pispbe 1000880000.pisp_be: config device node registered as /dev/video37
[ 5.165665] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.166659] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 5.167987] rpivid 1000800000.codec: Device registered as /dev/video19
[ 5.213227] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.221709] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.221882] usbcore: registered new interface driver brcmfmac
[ 5.321259] Bluetooth: Core ver 2.22
[ 5.327953] NET: Registered PF_BLUETOOTH protocol family
[ 5.327959] Bluetooth: HCI device and connection manager initialized
[ 5.327967] Bluetooth: HCI socket layer initialized
[ 5.327970] Bluetooth: L2CAP socket layer initialized
[ 5.327979] Bluetooth: SCO socket layer initialized
[ 5.347207] Bluetooth: HCI UART driver ver 2.3
[ 5.347216] Bluetooth: HCI UART protocol H4 registered
[ 5.347241] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 5.347480] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 5.347532] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 5.348212] Bluetooth: HCI UART protocol Broadcom registered
[ 5.352432] alsactl[435]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 5.591862] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 5.592310] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[ 5.700445] Bluetooth: hci0: BCM: chip id 107
[ 5.700682] Bluetooth: hci0: BCM: features 0x2f
[ 5.702084] Bluetooth: hci0: BCM4345C0
[ 5.702093] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 5.708017] Bluetooth: hci0: BCM4345C0 ‘brcm/BCM4345C0.raspberrypi,5-model-b.hcd’ Patch
[ 5.926804] Adding 204784k swap on /var/swap. Priority:-2 extents:9 across:2015232k SS
[ 6.041177] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.041185] Bluetooth: BNEP filters: protocol multicast
[ 6.041191] Bluetooth: BNEP socket layer initialized
[ 6.464575] Bluetooth: hci0: BCM: features 0x2f
[ 6.465952] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3±0190
[ 6.465955] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[ 6.466440] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[ 6.488511] Bluetooth: MGMT ver 1.22
[ 6.496381] NET: Registered PF_ALG protocol family
[ 6.786600] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[ 6.786609] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 6.789190] pps pps0: new PPS source ptp0
[ 6.789241] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[ 6.818476] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 6.916342] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[ 8.673841] Bluetooth: RFCOMM TTY layer initialized
[ 8.673852] Bluetooth: RFCOMM socket layer initialized
[ 8.673861] Bluetooth: RFCOMM ver 1.11
[ 10.892978] macb 1f00100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 54.549793] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
rich@PI5-Server:~ $ journatlctl
bash: journatlctl: command not found
rich@PI5-Server:~ $
The preformatted text button </> will wrap it in code tags and make it easier for reading by others.
on debug screen it said m.2 hat not found
Hi @rich.danler try inputting
sudo dmesg | grep -i nvme
into a terminal and please post the output. 👍
sudo dmesg | grep -i nvme = no output
Okay, thanks. Strange.
What’s also a little strange is that your posts show that:
Which not yet possible on the Pi5, as it’s Gen2/3 only.
This is definitely one for support if you haven’t contacted them already. Strongly recommend raising a ticket here. Hope they can get you sorted.
It was a bad cable that caused all the problems
Thanks to all who helped
Rich
