On/off shim + Button shim or Pibrella
Quick question,
Can the on/off shim be used with either the button shim or Pibrella, please?
Loads of thanks!
The button shim uses i2c so it should be fine, https://pinout.xyz/pinout/button_shim#
The Pibrella looks like it conflicts though, https://pinout.xyz/pinout/pibrella#
BCM 4 Pin 7 and BCM 17 Pin 11 are used on both. https://pinout.xyz/pinout/onoff_shim#
